Oil Cooler - pressure
Old May 30, 2004 | 12:43 PM
swlabhot's Avatar
Default Oil Cooler - pressure
Those of you runnning oil coolers in your turbo setups, what do you do about your oil pressures? Fitting a higher pressure oil pump?
Old May 30, 2004 | 02:26 PM
mike1114's Avatar
Default Re: Oil Cooler - pressure (swlabhot)
I have been tossing the idea around of installing a pump on the oil drain off the turbo and running it to a oil cooler then to the oil pan to cool the oil down some. I even found an oil cooler that looks like a small intercooler that I would mount in the top grill section of my 97 civic.
I don't think you need a larger pressure pump, just a little more oil to compensate for the cooler and lines.
oscar112709
Apr 18, 2019 12:52 AM
tcontesh
Jun 29, 2006 01:46 PM
crxsiperf
Nov 23, 2005 04:36 PM
rondigs
Jan 24, 2002 07:37 AM
