internall wastegate actuator question
Old May 29, 2004 | 12:48 PM
SOHC_MShue's Avatar
Default internall wastegate actuator question
hey guys i was wondering if you are suppost to be able to move your actuator arm in and out of the actuator with a little force? Or does it have to see boost to move at all? I'm just wondering because i can't budge my actuator arm by pulling on it with a little force. Just don't want my wastegate not to open
Old May 29, 2004 | 01:41 PM
k9n's Avatar
k9n
Default Re: internall wastegate actuator question (SOHC_MShue)
i dont know about your question, but i assume you are runing the 14b (td05)? Do you know how to lower boost if possible with an internal wg?
Old May 29, 2004 | 01:50 PM
sporkcrx's Avatar
It's pretty hard to do it with the actuator attached. The arms are pretty tough to move. If you want to see if your flapper isn't stuck, just take the arm off the flapper and check it out.
Old May 29, 2004 | 02:08 PM
igo4bmx's Avatar
it takes a bit of force to move the arm...
i tested mine out once buy using an electric pump and a hose to make sure the arm moves.. and it did
Old May 29, 2004 | 05:13 PM
quik sol's Avatar
I welded my internal wastegate....no worries now...I let the Tial handle the wastegate
Old May 29, 2004 | 10:48 PM
SOHC_MShue's Avatar
yea i gave it some more force and got it to move . My flapper works fine and its on a wrx turbo. I would like to weld it and get a tial, but i'm not a baller
mikeyp5d
Dec 28, 2005 11:00 AM
EH-3
Dec 2, 2005 02:11 PM
60-1
Mar 18, 2004 11:30 PM
turbodelsolman
Mar 13, 2003 08:07 PM
