turbo timer with alarm?
Old May 27, 2004 | 03:24 PM
Superorb's Avatar
Default turbo timer with alarm?
how in the hell do i get my alarm to work along side a greddy turbo timer?? i just installed it tonight.
i have a diagram to do it, but it just says main ign wire. which one is that?
Old May 27, 2004 | 03:41 PM
showtymers619's Avatar
* B A N N E D *
Default Re: turbo timer with alarm? (Superorb)
just do this...
it will make things ALOT easier...
set your turbo timer under 30 seconds
and put your alarm on "auto arm"
just do this step it will work out
test senario: car on you inside. take key out wait 5 seconds open door and lock manualy.. close door..now wait.. car shoudl turn off and unlock the door and the alarm should set 30 seconds after the last door that was closed.. it will unlock your car then the alarm will set and lock all the doors
Old May 27, 2004 | 03:42 PM
pip9's Avatar
goodluck on that one. I tried to get this question answered a long time ago and never got anything back that worked correctly. I had a DEI alarm and once my turbo timer shut off the doors would unlock so i'd have to sit in my car and wait. It got real annoying. If u figure it out let me know.
edit: Sometimes u need the turbo timer left on for more than 30sec. so i couldn't do that.
Old May 27, 2004 | 04:24 PM
Superorb's Avatar
well, regardless, if the tt is set above or below 30 seconds, the alarm waits till after the door is open, aka someone leaving the car, before it starts the countdown when the last door is closed. if you take the key out, open the door and shut it, it wont do anything, then when the car shuts off, it unlocks the doors and waits for the door to open again, it will hang there forever, unless you open a door or manually arm it...
Old May 27, 2004 | 04:27 PM
Superorb's Avatar
this is what i found, i dunno if it will work tho, i have a relay sitting here, and it all looks confusing
Old May 27, 2004 | 04:31 PM
Superorb's Avatar
ok, this diagram makes sense in my head w/ the wires i already have, but anyone know which one there referring to as the "main ign wire" must be a wire where the alarm only taps off a tee for it, either the ACC or the ON wire, solid yellow or black/yellow... a 6th gen accord guy's wires are different than the ones in my 5th gen... weird, huh... cause mine works fine, and im guessing his does too
Old May 27, 2004 | 04:39 PM
M.A.R.C.'s Avatar
Default Re: (Superorb)
search i think someone posted the instructions how to wire up that relay diagram i showed u.
Old May 27, 2004 | 05:10 PM
Superorb's Avatar
tell me, oh great jdm afro*****.... what do i search for, cause i cant find anyhting
Old May 27, 2004 | 05:20 PM
M.A.R.C.'s Avatar
search for... "turbo timer alarm" in the archives though
Old May 27, 2004 | 05:22 PM
MachAF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superorb &raquo;</TD></TR><TR><TD CLASS="quote">tell me, oh great jdm afro*****</TD></TR></TABLE>
bahahahahahhahahahaha
Old May 27, 2004 | 05:29 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superorb &raquo;</TD></TR><TR><TD CLASS="quote">oh great jdm afro*****...</TD></TR></TABLE>
hehe that would be me. i prefer... "jamasian" or "chinegro"... JDM is too played out
Old May 27, 2004 | 05:45 PM
Superorb's Avatar
Default Re: (CivicRyda2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">search for... "turbo timer alarm" in the archives though</TD></TR></TABLE>
drrr... i did, but not in the archives.. im looking now
Old May 27, 2004 | 06:51 PM
Blazin Civic's Avatar
Buy a compustar...great alarm and it comes with a built in turbo timer feature. It actually arms the alarm while the car turbo times since it is built into the alarm.
Old May 27, 2004 | 06:55 PM
GSRrR's Avatar
i know how to do it. dustin showed it to me a long time ago. let me finish dinner, lakers game and i will draw up some diagrams....you need a relay and a diode
check back later for the edit
EDIT:
First of all you need a SPDT (single pole double throw) Relay and a 1amp diode (1N4001). I would suggest you get a good one like Bosch (Ebay) and a diode from radioshack http://www.radioshack.com/prod...-1101.
wire it up like so (thanks to skafia for the host)....
I will explain what it all means.
the gray wire on the greddy timer is ground when the timer is counting down. the red wire is any 12v +. you can switch the wires to either sides BUT the cathode side (stripe side) has to go to 12+ and anode (no stripe) has to go to ground. the diode is place in between the two post of the relay to protect it.
"Diode across the coil of a relay:
The diode provides a path for current when the current path to the relay is interrupted (i.e. switched off). This allows the coil field to collapse without the voltage spike that would otherwise be generated. The diode protects switch or relay contacts and other circuits that may be sensitive to voltage spikes." - the12volt.com
you then find the wire that sends a signal to the alarm that lets it know that the engine is on (12v+ ign). you cut that wire and wire one side to 87a and other to 30.
what this does it when the timer is counting down, it send voltage across the coil which opens the connection between 30 and 87a. the alarm thinks the engine is off and lets you arm it. after the timer counts down, the circuit is then reconnected.
this works for me and my friend. please try at your own risk. i take no responsibility if you mess up and good luck
Modified by GSRrR at 8:26 PM 5/27/2004
Modified by GSRrR at 8:29 PM 5/27/2004
Old May 27, 2004 | 06:57 PM
Superorb's Avatar
i read a zillion posts, everyone says somethign different... some say 4 post, some say 5 post... why cant we just hook the alarm to the acc wire instead of the ON wire?
Old May 27, 2004 | 07:32 PM
lonnieboost's Avatar
Ok Take note. The alarm is mainly hooked up on the 1st ignition wire. Remove it and put to the accessoriy wire, (the one that shows 12v when the radio turns on.) Then hook up the turbo timer, but just powering ignition 1( The wire that sees 12v when in the on and start position) You will be fine.
Old May 27, 2004 | 07:40 PM
Superorb's Avatar
well, the alarm already is hooked up on the acc wire i think. ok, this is what i dont get.... i have a black/yellow, a black/white, and a solid yellow. which wire is the black/yellow wire? b/c that's what i have the turbo timer hooked up to
Old May 27, 2004 | 07:42 PM
Get a test light a check it. I cannot remember the color codes right now
Old May 27, 2004 | 08:37 PM
Trak_Day's Avatar
New User
lose the TT and drive lightly for the last mile of your drive, although i understand that is not the answer you were looking for
Old May 28, 2004 | 08:46 AM
VNTEC's Avatar
B A N N E D
Default Re: (DroppedGSR)
What if the car unlocks when the motor turns off.. Then what?
Old May 28, 2004 | 09:46 AM
Superorb's Avatar
then, it might be a good idea to deisable that setting, i didnt even think of that
Old May 28, 2004 | 09:53 AM
Default Re: (VNTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC &raquo;</TD></TR><TR><TD CLASS="quote">What if the car unlocks when the motor turns off.. Then what? </TD></TR></TABLE>
This would not happen if you put the alarm wire to acc.
Old May 28, 2004 | 10:03 AM
Superorb's Avatar
ok guys, i just did it, hook tha alarm to ACC, white wire with black STRIPE, this works, my shock sensor doesnt get pissed, all is good!!!!
Old May 28, 2004 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superorb &raquo;</TD></TR><TR><TD CLASS="quote">ok guys, i just did it, hook tha alarm to ACC, white wire with black STRIPE, this works, my shock sensor doesnt get pissed, all is good!!!!</TD></TR></TABLE>
niceness
Old Jul 29, 2004 | 04:57 PM
accordium's Avatar
Default Re: turbo timer with alarm? (GSRrR)
is this applicable to the factory honda alarm?
