ecu dizzy
Old May 28, 2004 | 04:42 AM
RACEPAK's Avatar
Default ecu dizzy
can i turbocharge my car with the stock ecu?? or do i have to burn a chip??.
i dont understand the whole Burning process.
anyone have the process in pics??
Old May 28, 2004 | 07:21 AM
DaveF's Avatar
Default Re: ecu dizzy (RACEPAK)
you have to get your ecu "socketed" in order for it to be able to accept a "chip"
the burning process, is only a matter of taking the chip out of the ecu, putting it in the romulator, making adjustments on your computer(to fine tune the chip) ... than "burn" them adjustments onto the chip.. after that.. take the chip off the romulator, re-install back into the ecu.. go for another dyno run.... repeat the process if neccesary.
J.Davis will be able to help you out more on this subject.
Old May 28, 2004 | 08:16 AM
RACEPAK's Avatar
Default Re: ecu dizzy (Dturbocivic)
please correct me if i wrong
1)take out the ecu.
2)open it.
3)desolder the EPROM.
3)burn a new onen.
4)solder new back
5)goto dyno??
thats it??.......so simplle....??
what is the best site that will explain the process best?...
didnt understand this(http://ecucontrol.com/images/finished_inside.jpg)
Old May 28, 2004 | 08:43 AM
DaveF's Avatar
Old May 28, 2004 | 10:52 AM
RACEPAK's Avatar
can i just use a apexi s-afc or v-afc ??
wouldnt it be more simple?.
Old May 28, 2004 | 11:02 AM
DaX's Avatar
DaX
Loved
Community Favorite
Yes, you can. But with simplicity comes a cost in capabilities and performance.
Old May 28, 2004 | 11:11 AM
Joseph Davis's Avatar
You solder in a socket to your ECU, and then the chip plugs in and out of it easily.
You can get a chip burner and everything you need for $85-150 depending on what you buy. It's a better spend of money than an AFC by far.
What is your setup?
Old May 28, 2004 | 12:39 PM
RACEPAK's Avatar
Default Re: ecu dizzy (J. Davis)
setup is on a euro civic 94 hatchback ESI
ihi rhb5
hf manifold + custom DOWNpipe
10.5''/8.5''/2.5'' intercooler
440cc injectors dsm
need to get: manual boost controller / bov / oil lines / gauges.
i will be able to buy an apexi s-vafc or v-afc (dont remember) from a frined for $60 (wires cut 5'' from instrument) isn't it worth the effort?
Old May 28, 2004 | 12:52 PM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">,re-install back into the ecu.. go for another dyno run.... repeat the process if neccesary.
what like desolder the rom and burn it again?
i dont understand this picture: http://ecucontrol.com/images/finished_inside.jpg
ecucontrol.com made me dizzy. what is this connector?
any one can post pictures of:
28 pin socket
4 pins "jumper" connector
TTL to RS-232 or TTL to USB converter.
4 conductors wire
Old May 28, 2004 | 10:28 PM
AFCs work, but they alter your ignition timing as much as your fuel values. You end up with ignition advanced past where it should be for the lower psi boost event. If you are intimidated with soldering and chip burners and such, an AFC might be an option for you to consider, but I'd read up on Uberdata before you run out and grab that AFC.
Old May 29, 2004 | 12:16 AM
RACEPAK's Avatar
soldering is a piece of cake.
and i guess the burning process too
from what i understand the prosess goes like this:
1)take off ecu from vehicle
2)open it
3)desolder the rom.
4)burn a new rom.
5)solder new rom
6)adding/soldering some capasitors and resistors.
7)close the ecu.
8)done. go to dyno.
can someone correct me if i'm wrong
Old May 29, 2004 | 05:55 AM
DaX's Avatar
DaX
Loved
Community Favorite
https://honda-tech.com/zerothread?id=772172
details and a picture near the bottom.
You don't remove the stock "ROM"...you desolder the holes where the auxillary ROM goes and solder in a socket [I prefer using a standard socket soldered in and a ZIF socket stacked on top] so that you can add/remove the new ROM at will.
jthrasher1
Jan 25, 2010 08:41 PM
mahatma
Jun 7, 2007 10:59 AM
1990 CRX Si
Nov 16, 2005 10:44 AM
