help!! coolant in oil.....
Old May 10, 2005 | 01:44 PM
primeredbeast's Avatar
Default help!! coolant in oil.....
well today i drained the oil and wtf figures a milky substance comes out instead of oil I did a compression test with 175 all the way across the board . setup is a b16 stock block with turbo stuff. Motor hasn't even seen boost yet. im leaning towards headgasket, but i figured it would have lost compression somewhere. anyone got any ideas thanks -tim
Old May 10, 2005 | 04:27 PM
turbosi03's Avatar
Default Re: help!! coolant in oil..... (primeredbeast)
check to see if there's oil in your coolant system... how many miles on the block?
compression wont always be low if its the head gasket... it's possible there's a leak only when your pushing the motor and things heat up.
thats all I can think of right now... good luck!
Old May 10, 2005 | 04:30 PM
GDM Z28's Avatar
Default Re: help!! coolant in oil..... (turbosi03)
its a head gasket change it and use ARP's
comp checks suck....do a leak down test it owns
Old May 10, 2005 | 05:16 PM
Muckman's Avatar
Moderator in Chief
175 seems pretty low for a stock compression b16...
Old May 10, 2005 | 08:35 PM
Rod.'s Avatar
Default Re: help!! coolant in oil..... (Muckman)
bump for more answers
Old May 10, 2005 | 10:08 PM
GDM Z28's Avatar
Default Re: help!! coolant in oil..... (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">bump for more answers</TD></TR></TABLE>
what other answers do u want? no one on the internet can tell him exactly whats wrong...he needs to pull the head n find out
Old May 10, 2005 | 10:20 PM
Redwidow's Avatar
When i had coolant mixing in my oil & it was under 40 miles my turbo was toast and my cams were damaged and also the bearings on the bottom end. Coolant is not good in your oil. even if it is your HG your probably not gonna be happy about all the damage that has occured. Here is some pics as you can see the mixed coolant and the damage to the cams it had caused.
Old May 11, 2005 | 12:12 AM
FredoSP's Avatar
Default Re: help!! coolant in oil..... (Redwidow)
holy crap, thats bad
Old May 11, 2005 | 04:22 AM
turbosi03's Avatar
Default Re: help!! coolant in oil..... (FredoSP)
those cams don't look bad to me... I think you can still use them.
but yeah milk does a body good, NOT a motor...
just so you know I speak from experience...
but anyway, do the things suggested above and let us know the results. do a leak down before you pull the head.
Old May 11, 2005 | 04:56 AM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">those cams don't look bad to me... I think you can still use them.
Well the cams were black Im guessin some type of coating that they have on them. But they were shinny and most of the black was gone when i pulled my head. But...
Yeah I used the cams again, but @ 40 miles the mains and rod bearings were scored also and turbo had to get rebuilt. O yeah I been here 2 not fun
Old May 11, 2005 | 07:32 AM
BoostedA6's Avatar
you said you have turbo stuff? A turbo I am assuming? Is it oil/water cooled?
If so it is possible that the seals in the turbo are bad and the coolant and oil is mixing there. Is there signs of oil in the coolant?
Old May 11, 2005 | 07:53 AM
hatchinprogress's Avatar
Default Re: help!! coolant in oil..... (BoostedA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedA6 &raquo;</TD></TR><TR><TD CLASS="quote">you said you have turbo stuff? A turbo I am assuming? Is it oil/water cooled?
If so it is possible that the seals in the turbo are bad and the coolant and oil is mixing there. Is there signs of oil in the coolant? </TD></TR></TABLE> yeah check that out
Old May 11, 2005 | 07:57 AM
Rod.'s Avatar
Default Re: help!! coolant in oil..... (hatchinprogress)
its a brand new turbo
Old May 11, 2005 | 08:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">its a brand new turbo</TD></TR></TABLE> is it coolant cooled? or just oil cooled? or both? either way id check the seals
Old May 11, 2005 | 09:09 AM
Rod.'s Avatar
oil... i doubt it is the seals, but he will probably check it once he sign on
Old May 11, 2005 | 09:15 AM
EJ1 wilcox's Avatar
As far as I know there is no way that the oil and coolant can mix in the turbo. The water jacket is completely sealed off from the oil passage, there is no seal or anything like that between them.
My guess is the problem is head gasket related.
Old May 11, 2005 | 12:34 PM
Default Re: help!! coolant in oil..... (EJ1 wilcox)
thanks for reply's turbo is oil cooled only thing i did recently was put an intake manifold on the car has been just sitting in my garage ......im gonna do a leakdown test and see what's up
Old May 11, 2005 | 03:02 PM
ok so i pulled the head off all coolant around the cylinders has NO oil in it. as far as i can tell the head gasket looked fine piston tops looked fine also no oil or coolant on top of the cylinders i dunno what the deal is what else should i check for? before i pulled the head off all the oil in the head was mily also. anyone got any ideas i was planning on putting pistons and rods in anyways i guess now im forced too
Old May 12, 2005 | 04:51 AM
turbosi03's Avatar
take the head and block to a machine shop have them check for straitness on both head surface and block deck before putting it together. it's possible the head is warped causing the leak...
you should find out exactly why you had milk before putting the pistons/rods in...
I hope the answer comes up man
Old May 12, 2005 | 01:02 PM
well i looked at everything closer and i caught it right when it happened i believe one of my pistons was a little cleaner than all the other ones and i believe thats where the gasket started to separate im gonna take the head to get checked out here before too long good thing is the car only ran for probably a minute or so we'll see what happens
Old May 13, 2005 | 08:18 PM
Bror Jace's Avatar
If you suspect coolant in your oil, try a UOA:
http://www.blackstone-labs.com/
This is one of MANY labs which performs this kind of service.
Tell them what you expect/fear is happening and for $20 you'll have a lot better answer than you will with a compression or pump down test. UOAs can detect a trace coolant leak by looking at the additives and the iron and lead wear levels.
And yes, even trace amounts of glycal will cause wear metals to spike.
Old May 13, 2005 | 08:28 PM
Tad's Avatar
Tad
but anyway, do the things suggested above and let us know the results. do a leak down before you pull the head. </TD></TR></TABLE>
hahaha , that pic is infamous
classic "milkshake" effect
Old May 13, 2005 | 08:32 PM
alexsracing's Avatar
dosn't mix well
avotegra
Dec 13, 2009 11:45 PM
an2ny888
Jul 4, 2008 07:40 AM
huge230
Dec 18, 2006 07:29 AM
blackeg
Mar 27, 2006 03:52 PM
92HatchB16
Sep 28, 2005 12:28 PM
