2.5bar map sensor
http://www.digikey.com
18bucks... i forget the serial# info though. Check http://www.homemadeturbo.com
edit: found my invoice. MPX4250AP-ND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic »</TD></TR><TR><TD CLASS="quote">curious, does this map sensor work like the gm map sensor. I plan on running 12psi tops with my uberdata. Just wanna know if this is all i need.</TD></TR></TABLE>
Bump your max down to 10-11 and you can keep the stock MAP, but yeah, if you go over the stock map, this should work. I have one, just haven't installed it and retuned.
i got one with splitime from digikey or whatever...we hooked it up on saturday to test it out, and we'll be re-tuning the car tonight....
pretty excited to be able to turn the boost up, once my bottom end is complete.
you can stretch the stock mapsensor to 12psi no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 »</TD></TR><TR><TD CLASS="quote">
you can stretch the stock mapsensor to 12psi no problems.</TD></TR></TABLE>
what do u mean by that? run 12 lbs and hope for no codes???
also i wanna give u props for keeping ur a/c with ur hf manifold!! good job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 »</TD></TR><TR><TD CLASS="quote">you can stretch the stock mapsensor to 12psi no problems.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">http://www.digikey.com
edit: found my invoice. MPX4250AP-ND</TD></TR></TABLE>
What a deal.
What a deal.
i've pushed up to 14psi...it get tricky though because you have to manipulate your fuel and timing in the 11psi columns.
i've got 5 sample 2.5 bar mapsensors on the way. hope to see them before the end of the week.
