2 LS/VTEC questions
Old May 11, 2005 | 08:27 AM
quik sol's Avatar
Default 2 LS/VTEC questions
ok...these are two I have been juggling through my brain, I have a 1994 Honda Del Sol VTEC with a B16a3, I am going to be changing it over to a turbo LS/Vtec here in a couple more weeks. I was curious about two things:
1. Will my mounts for my B16 work with the lsvtec engine?
2. Will I be able to keep my 8200 rpm redline with cp pistons and eagle rods (but stock sleeves, and stock head)?
Old May 11, 2005 | 08:48 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: 2 LS/VTEC questions (quik sol)
yes your mounts will work.
you should be able to rev it to 8200, but you might not need to go that high to make your desired power
Old May 11, 2005 | 08:53 AM
BoostedSiRhc's Avatar
Default Re: 2 LS/VTEC questions (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">yes your mounts will work.
you should be able to rev it to 8200, but you might not need to go that high to make your desired power</TD></TR></TABLE>
Old May 11, 2005 | 08:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: 2 LS/VTEC questions (BoostedSiRhc)
i'll be turning my b20.vtec to around 10k at the track, 9k on the street (give or take a few hundred) but only becuase i'll have a girdle, arp mainstuds and a knife edged and balanced crank
Old May 11, 2005 | 01:42 PM
quik sol's Avatar
cool, well the goal is 375 maybe 400 if boosted-hybrid can do it safely
Old May 11, 2005 | 02:05 PM
vaporboy12's Avatar
Default Re: (quik sol)
rev it higher
Old May 11, 2005 | 02:53 PM
0bd1_Kanobe's Avatar
Torque on a LS/Vtec is really good so I say 8k rpm should be good. Rev mine to 8k cause after that power starts to fall........Soichiro Garage 7
Old May 11, 2005 | 03:03 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (BseriesHybrid)
^stock head? what turbo?
Old May 11, 2005 | 10:39 PM
quik sol's Avatar
Precision GT32E
Wilmer787
Mar 20, 2006 12:44 PM
De_tour
17
Jan 9, 2006 10:02 AM
RACING INTEGRATION
Oct 27, 2004 03:02 PM
turbotypeR@SPEC
Jun 7, 2003 11:23 AM
