weird wg problem advice needed
Old May 8, 2005 | 09:46 PM
hotrex's Avatar
Default weird wg problem advice needed
well at full boost and the wg open, i shift and the wg stays open for a sec or 2 and then closes and builds boost. i dont understand why the wg is hanging open. only viable reason i can think of is that the 5 psi spring is too soft to close the wg quickly enough while fighting the exhaust flow.
any ideas what might cause this btw, its a tial 38mm wg with about 700 miles on it.
Old May 9, 2005 | 03:10 PM
hotrex's Avatar
Default Re: weird wg problem advice needed (hotrex)
ttt
Old May 9, 2005 | 03:13 PM
y7turbo's Avatar
where is the wastegate line hooked up to.. and what does this problem cause? does it slow your spool after you shift or something?
Old May 9, 2005 | 03:37 PM
hotrex's Avatar
Default Re: weird wg problem advice needed (konigturbocivic)
yeah its teed into the brake booster, so vac source isnt the prob
Old May 9, 2005 | 03:49 PM
dustin's Avatar
Before or after the check valve? hehe I guess before, else you'd be seeing more boost than that
But yeah, the problem probably isn't your wastegate. You sure your BOV isn't leaking etc?
Old May 9, 2005 | 04:13 PM
hotrex's Avatar
Default Re: weird wg problem advice needed (dustin)
you can hear the wg dumping even after the shift... i know uits the wg hanging open not the bov leaking.
Old May 10, 2005 | 12:20 AM
O3DigitalBath's Avatar
bump cause i'm interested in why
krazyhmongboi
Jul 6, 2006 08:22 AM
PooOnMyShoe942
Sep 30, 2005 04:50 PM
crazyimport
Jul 14, 2004 06:08 PM
SPOOLINTEG
May 24, 2004 07:22 AM
aracer69
Jul 8, 2003 07:01 AM
