missing link instead of 3 bar map sensor
Old May 10, 2005 | 12:15 PM
redlseg's Avatar
Default missing link instead of 3 bar map sensor
can i just use a missing link instead of a 3 bar map sensor?
Old May 10, 2005 | 12:18 PM
N20civicB18's Avatar
Default Re: missing link instead of 3 bar map sensor (95gsrhatch)
WHAT??!!? umm noo a missinglink tricks the map sensor into not seeing boost and a 3 bar mad will jsut do funky things without a chip... stock map sensors will handle 11psi no problem with a chiped pcm.. goind back to bed.. SEARCH
Old May 10, 2005 | 12:27 PM
redlseg's Avatar
Default Re: missing link instead of 3 bar map sensor (N20civicB18)
no **** sherlock i already did a search and found nothing. i got a hondata s200 and a p28 chipped for it already. i want to boost up higher but i dont want to buy a gm 3 bar map. i was wondering if a missing link will work. well i'm going back to scratching my *****
Old May 10, 2005 | 12:32 PM
Mase's Avatar
you'll spend thousands of dollars on a turbo setup and not 50 bucks to ensure a proper way to tune the engine?
Old May 10, 2005 | 12:33 PM
tgreaves's Avatar
Probably what you want to do is read up and find out what a missing link does and what a map sensor does(and the different types) and youll have answered your own question..
Old May 10, 2005 | 12:36 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote">can i just use a missing link instead of a 3 bar map sensor?</TD></TR></TABLE>
Don't work on your car yourself. Take it somewhere.
Old May 10, 2005 | 06:25 PM
Zero2Sixty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote">no **** sherlock i already did a search and found nothing. i got a hondata s200 and a p28 chipped for it already. i want to boost up higher but i dont want to buy a gm 3 bar map. i was wondering if a missing link will work. well i'm going back to scratching my *****</TD></TR></TABLE>
just go back to allmotor u will prolly do better at that!
Old May 10, 2005 | 07:28 PM
zseeanz's Avatar
If you're using hondata then get a 3 bar. Hondata reads off the map sensor. You can't use missing link with hondata.
Old May 10, 2005 | 08:18 PM
sharkcohen's Avatar
So what you are saying is you have no idea what a missing link is or what it does.
Old May 10, 2005 | 08:19 PM
Default Re: missing link instead of 3 bar map sensor (zseeanz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz &raquo;</TD></TR><TR><TD CLASS="quote">
If you're using hondata then get a 3 bar. Hondata reads off the map sensor. You can't use missing link with hondata.</TD></TR></TABLE>
Sure you CAN it just kinda eliminates the point to even having hondata... I guess if you were going ot use check valves (missing link) for whatever reason you would also want to put on a FMU because your ecu will not be reading boost so therefor it will not be giving it more gas when ur in boost so u will fry your motor. I just bought a 3 bar for 55$ of ebay and got a pigtail from a junk yard, took 20 min to put it in, then you just need to have a new chip burned and you did it the right way and you wont have to worry about anything (after u have it tuned) umm blah blah blah you get the point and im a lil tipsy right now so im going to bed, if it dont make sence just ignore it
peace
Old May 10, 2005 | 09:07 PM
redlseg's Avatar
man f@ck yall, u all where noobs too. and for that comment of going back to allmotor get a better come back and stop being a stocker and get a life or a girlfreind..
Modified by 95gsrhatch at 10:24 PM 5/10/2005
Modified by 95gsrhatch at 10:25 PM 5/10/2005
Old May 10, 2005 | 09:12 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">
There is your answer right there man..
No need for this ****:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote"> man f@ck yall, u all where noobs too. and for that comment of going back to allmotor get a better come back and stop being a stocker and get a life or a girlfreind. </TD></TR></TABLE>
Old May 10, 2005 | 09:23 PM
redlseg's Avatar
Default Re: missing link instead of 3 bar map sensor (jBj)
i'm not trying to start **** but ppl need to stop acting like ***'s i'm a damn noob what do u expect. of coarse i'm going to ask some dumb *** questions but u dont have to answer back being an *******
Old May 10, 2005 | 09:26 PM
reaction360's Avatar
this post is garbage. lock it
Old May 10, 2005 | 09:38 PM
redlseg's Avatar
Default Re: missing link instead of 3 bar map sensor (reaction360)
yes lock it...........
Old May 10, 2005 | 09:40 PM
G
sh!t happens.
Man this thread went down In before it gets locked..lol
Old May 10, 2005 | 09:46 PM
redlseg's Avatar
Default Re: missing link instead of 3 bar map sensor (G"UNIT)
man i'm going to say the last **** on my post man.
Old May 10, 2005 | 09:58 PM
tony n.'s Avatar
dont be a smartass then people would respect ur noob ***
Old May 10, 2005 | 09:59 PM
tony n.'s Avatar
Default Re: missing link instead of 3 bar map sensor (boosted2cam)
oh yeah im a noob too i get the same **** lol
Old May 10, 2005 | 10:07 PM
redlseg's Avatar
i dont need no respect from these ppl.
Old May 11, 2005 | 02:29 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote">i dont need no respect from these ppl.</TD></TR></TABLE>
You know your original post was kinda vague. You should have included what your fuel and EMS setup was gonna be.
FMU = missing link and stock MAP sensor
standalone = no missing link and stock MAP sensor (for up to 10-11 PSI) or 3 bar MAP sensor for 24-25 PSI (or however much 3 bars are good for)
Old May 11, 2005 | 05:32 AM
tgreaves's Avatar
Default Re: (95gsrhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote"> man f@ck yall, u all where noobs too. and for that comment of going back to allmotor get a better come back and stop being a stocker and get a life or a girlfreind.. </TD></TR></TABLE>
Yes, we were all noobs at one point.. I was a member of honda-tech for like a year before I posted anything, all the time before that I used the search because someone else probably has already asked the questions that I needed answered..
Old May 11, 2005 | 06:48 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote"> ppl need to stop acting like ***'s </TD></TR></TABLE>
including yourself... don't take these responses so seriously.
IBTL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Don't work on your car yourself. Take it somewhere.</TD></TR></TABLE>
dustin you n00b!! nice avatar.
ganjasnack
Apr 18, 2008 06:08 AM
QwkD16
Jan 5, 2006 07:39 PM
B18Sleeper
Oct 26, 2005 12:52 PM
l2yanE
Oct 2, 2005 10:15 AM
gsrt2c
Jun 8, 2003 05:35 AM
