problem with sleathmode injectors
Old May 8, 2005 | 06:14 PM
92civic_eg's Avatar
Default problem with sleathmode injectors
hello
I was putting them on my 96 dx obd2 turbo civic and those sleathmode injectors wouldn't start my car unless you push the gas ,but if you let go the gas the engine will cut off. also I checked the resistance on those sleathmode injectors it is the same as my stock injectors ,which is 11.5 ohms. I also did wired up the clips. well I have no luck with those injectors and Please leave me some suggestion.
thanks for looking.
Old May 8, 2005 | 06:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: problem with sleathmode injectors (92civic_eg)
are you running the stock ecu?
Old May 8, 2005 | 06:31 PM
92civic_eg's Avatar
Default Re: problem with sleathmode injectors (wantboost)
yea, well what should I use to control it
Old May 8, 2005 | 06:37 PM
wantboost's Avatar
Who is Mr Robot?
stock ecu wont idle those injectors... get something like hondata or uberdata, you need to be able to adjust the maps for the bigger injectors
Old May 8, 2005 | 06:41 PM
92civic_eg's Avatar
hello
will safc be able to control it???
Old May 8, 2005 | 07:22 PM
non-VTEC's Avatar
how much bigger than stock are those injectors?
if there anything more than 400cc i dont think you can control them enough with just a SAFC.
Old May 8, 2005 | 07:27 PM
93turbo16's Avatar
Default Re: problem with sleathmode injectors (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">how much bigger than stock are those injectors?
I think you can do up to 500cc with the safc.. I did 450s on the old school SAFC with only -30% taken off. The new ones go to like 50%, so they can handle it.
Old May 8, 2005 | 07:43 PM
project dc2's Avatar
Default Re: problem with sleathmode injectors (93turbo16)
stealth mode injectors -= sturated 450's
search AFC HACK&gt;
Old May 8, 2005 | 09:57 PM
stealthmode62's Avatar
Default Re: problem with sleathmode injectors (project dc2)
If anyone is having a problem with a product I sold you, please feel free to contact me directly. -Steve
TokuiAutowerks
Jun 19, 2008 06:02 PM
top end tuner
Sep 24, 2007 08:41 PM
LILSOWEK
Oct 18, 2006 04:08 PM
bootlegtrader
10
Sep 19, 2005 05:40 AM
