cleaning a turbo???
Old May 11, 2005 | 01:29 AM
crazychrisjdmcrx's Avatar
Default cleaning a turbo???
just curious, whats the best way to go about cleaning a turbo, intercooler, piping, etc. what kind of solvents or solutions should i use to clean the build up out of the pipings and turbo?
Old May 11, 2005 | 01:49 PM
BoostedA6's Avatar
Default Re: cleaning a turbo??? (crazychrisjdmcrx)
I would recomend brake parts cleaner in the aerosol can. works like a charm to remove most residues i.e. oil build up, grease, carbon, etc.
If you plan to clean the turbo internally do not do anything without rebuilding it or at least remove the housing you plan to clean. If you don't it'll remove the **** that is built up and let it run into places you dont want it. it works fine though to clean the inside of your charge piping and such as it leaves behind no residues.
oh yeah don't use this stuff on anything that is rubber or plastic as the methyl hydrate or achohols(depending on the base) will dry it out.
hope this helps, worked awesome for me!!!
Old May 11, 2005 | 02:02 PM
CRXDrew's Avatar
gas works niec to clean IC pipes.. also dish soap.. "cuts grease fast"
nota-eg
Jul 6, 2005 07:20 AM
RACEPAK
Jul 20, 2004 01:55 PM
Nader_D
Oct 6, 2003 05:41 PM
FuzzyGreen
Sep 3, 2003 08:23 AM
kr
May 12, 2003 04:55 PM
