LSturbo problems
Old May 9, 2005 | 11:20 PM
ctap's Avatar
Default LSturbo problem
just turboed the ls about 3 weeks ago, the car was running around 5psi and the a/f at wot was around a mid to high 11. problem is, finally after getting the car started, because the car would not start until we changed the distributor and some old sparkplugs gapped at .050 the car is now idling with the a/f at low 10's. The sparkplugs were drentched with gas.
this is what ive changed: swapped the dsm 450's for another set, changed out the stock fpr for another, that is basicly it i just dont understand why it would be dumping so much fuel all of asudden.
fuel management is dsm 450's with turboedit software
any info would be much appreciated
Old May 10, 2005 | 01:29 AM
GDM Z28's Avatar
Default Re: LSturbo problem (ctap)
r u getting a solid cel? what happens when you try to lean it out?
Old May 10, 2005 | 06:26 AM
blackeg's Avatar
Default Re: LSturbo problem (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">r u getting a solid cel? what happens when you try to lean it out?</TD></TR></TABLE>
yea sounds like a limp mode thing. i was there briefly the other day and i was spitting wet fuel out of my exhaust tip. not good.
other small possibility is the coolant temp sensor. if malfunctioning it can cause you to run rich as hell.
are you throwing any engine codes???
Old May 10, 2005 | 06:32 AM
ctap's Avatar
Default Re: LSturbo problem (blackeg)
Im throwing out a code 8 which said its TDC sensor, thats about it, the car is shooting out the white smoke that dissapears right away and some fuel out the tailpipe. If it was the coolant temp sensor, would a code appear?
Old May 12, 2005 | 09:10 AM
duke96's Avatar
are you running resistors or a box for those injectors????
Maui Built
16
Jul 6, 2008 06:30 PM
Mrs . M i c h a e l
Mar 4, 2006 08:59 AM
drakarch
Sep 23, 2005 07:59 PM
fafsa
Feb 4, 2005 06:03 AM
JB3BELL331
Dec 13, 2004 06:33 PM
