Will this be good?
Old May 10, 2005 | 06:37 PM
boostedeghatch's Avatar
Default Will this be good?
jdm gsr motor
new main and rod beaings
new usdm pistons with new rings
p&p head with polished chambers
3 angle valve job
CTR intake cam
gsr exhaust cam
skunk2 intake manifold
some kind of turbo kit on 7psi ...
i was putting some b16 pistons in but the compression will be 11.4:1... a little too high for boost. i was going to go all motor, but i think i'm going to change my mind.
now with putting the usdm pistons in instead of the jdm gsr pistons, i will be at 10.2:1 on compression, should be good for boost. i don't plan on going higher than 7-8psi as i will be using a b16 tranny with 12lb flywheel.
what do you guys think?
Old May 10, 2005 | 07:28 PM
s2kdre's Avatar
Default Re: Will this be good? (boostedeghatch)
11:5 is good for boost but tunning is the key. My friend has 10:1 and 25psi tunned with hondata.
Old May 10, 2005 | 07:58 PM
Evanmb44's Avatar
just have it tuned well and it should be fine
_kiid
Sep 7, 2009 07:28 PM
bmwe362006
Aug 5, 2009 08:30 AM
LS-VTEC-TURBO-EF9
Sep 12, 2008 07:54 AM
stockb18c
Oct 1, 2006 12:30 PM
kenepo_vtec
Aug 26, 2004 12:34 AM
