will a 2001 honda odysee handle 5-6 psi?
im not sure what motor its got or the specs, but the guy wants to run 5-6 psi. will it need any upgrade to injectors or anything??
its got a vtec motor in it.
Re: (Sketch_hs)
specs:
3,471 cc 3.5 liters 6 V engine with 89 mm bore, 93 mm stroke, 9.4 compression ratio, overhead cam, variable valve timing/camshaft and four valves per cylinder
his van
http://www.hondashowoff.com/profile.php?id=3766
is a fmu really needed for 6 psi? we run 6psi on stock lt1s ( fbodies)
his van
Re: (nfn15037)
yup, ls1s too, well the MAF sensor takes care of the extra air coming in, adds fuel by itself.
i take it the newer hondas are still speed density
Re: (93formula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula »</TD></TR><TR><TD CLASS="quote">yup, ls1s too, well the MAF sensor takes care of the extra air coming in, adds fuel by itself.
i take it the newer hondas are still speed density</TD></TR></TABLE>
Yes....you will need a FMU at least.
Only honda I know of that had a MAF was the old passports made by Isuzu.
Re: (HXMan)
thanks, i guess we can find a used vortech fmu every one throws out, LOL.
yes the tranny is getting re done as well, hes also getting a aftermarket torque convertor
Re: (forcefedh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedh22 »</TD></TR><TR><TD CLASS="quote">why the hell would you want to turbocharge a minivan? Get the kids to disney land faster???</TD></TR></TABLE>
some may say why would anyone want to turbo charge a civic? so you can get to a grocery store faster
Re: (93formula)
Man i Love Fixed up Odysee'z....... I've seen a Turbo Dodge caravan rollin on VOlkz at a Qcup meet in Milpitaz one time...it was awsome
Re: (93formula)
Ahhh yes, I forgot about the MAF systems Freaking speed-density
Re: (forcefedh22)
Hahaha you just made my day
Re: will a 2001 honda odysee handle 5-6 psi? (93formula)
It comes w a motor similar to the NSX. VTEC V6 - and what do you mean will you have to upgrade it to injectors? Are you running sidedrafts on it or something?
The Destroyer
07-11-2004 03:33 AM
