what manifold for EVO VIII 16g?
local guy is sellin his stock evo turbo for hella cheap and ive decided to go turbo. so what manifold would i need to run the turbo?
You need a manifold that will fit the 16G...if you're running D-series engine...Just get a HF/Std exhaust manifold and port match the manifold to turbo...use adapter plate to adapt turbo onto manifold.
Re: (JDMlyfestyle)
16g to tiny for that motor.....hell we put an hx35 on a stock b16 and it was crazzzy...just start reading ull find lota **** on t3/t4 setups and **** for b16s which will better suit your needs....
for manifold look up lovefab, sfp, bmc, one fab, neukin, blox, full race any are good just a personal preference on which route to take....
Moderator
then you're looking in the wrong direction. The head flow efficiency of the honda is over 30% over the Evo. Specifically the Evo VIII uses a twin scroll design flange. that will have to be fabricated.
Plan on getting about 220whp or so from that setup. Not designed for honda...
GL
GL
Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">then you're looking in the wrong direction. The head flow efficiency of the honda is over 30% over the Evo. Specifically the Evo VIII uses a twin scroll design flange. that will have to be fabricated.
GL</TD></TR></TABLE>
I do agree with the special flange.. but I do believe that he will make more than 220 with that turbo. They are surprising little turbos.
Re: what manifold for EVO VIII 16g? (JDMlyfestyle)
You need a t-25 or t-28 manifold, and as for the tanged turbine housing you can go on ebay an get a 8cm turbine housing with a regular exhaust entry to replace the twin scroll entry.
$100 is a hell of a steal, I beleive that turbo has a titanium turbine shaft and spools quicker than any hybrid 16g.
Re: (JDMlyfestyle)
Evo 8 16g turbo ??
To tiny for a B16a????
You guys do know that turbo has put Curt Brown into the 10's ?
Also tons of others running that turbo in the 11's on 2.0L
http://www.garagedefeat.com/vi...o.wmv
There is video
There is video
Re: (STHPERFORMANCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STHPERFORMANCE »</TD></TR><TR><TD CLASS="quote">
Evo 8 16g turbo ??
Also tons of others running that turbo in the 11's on 2.0L </TD></TR></TABLE>
THANK YOU!!!!!!
I knew this turbo was a guy idea to go with. Just swap out the internal wastegate and get a 33mm external tial wastegate.
Evo 8 16g turbo ??
THANK YOU!!!!!!
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">THANK YOU!!!!!!
I knew this turbo was a guy idea to go with. Just swap out the internal wastegate and get a 33mm external tial wastegate.</TD></TR></TABLE>
U can get away with internal wastegate..
If you run external all u need to do is weld the wastegate flapper shut and mount wastegate on manifold..
If you run external all u need to do is weld the wastegate flapper shut and mount wastegate on manifold.. </TD></TR></TABLE>
Thats what im gonna do cause ill be running this on a stock block and i dont wanna risk and creeps or spikes.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Thats what im gonna do cause ill be running this on a stock block and i dont wanna risk and creeps or spikes.</TD></TR></TABLE>
Kewl, I just seen u posted it came off a MR EVo, I think the turbine housings on the MR are slightly larger then the normal turbine housing on the EVO Curt Brown put into the 10's
Re: (Bh8teen)
you can buy the manifold for the 16g from bmcrace.com thats where i bought mines for my ls turbo. and btw no way is the 16g too small and only make 220whp @ 15 psi on a b16 with that turbo is crazy, there is a guy in this forum with a 16g on his d16y8 with 13psi dyno @220-230whp , i also had a dyno on my old computer of a gsr turbo with the evo 16g @14psi and dyno @290whp hondata tuned. def keep the turbo.
