3 bar GM map sensor trouble
Old May 10, 2005 | 11:30 AM
jsimon9633's Avatar
Default 3 bar GM map sensor trouble
ok so I turn the car on and it idles very low like 400 and if i give it throttle it doesnt respond well and then stalls. could it be that my map sensor is just bad? any way to test it.
Old May 10, 2005 | 11:38 AM
s2kdre's Avatar
Default Re: 3 bar GM map sensor trouble (jsimon9633)
what ecu do you have because it doesnt work unless you have a chipped ecu
Old May 10, 2005 | 12:46 PM
jsimon9633's Avatar
Default Re: 3 bar GM map sensor trouble (jdmhonda)
i have a kpro
Old May 10, 2005 | 01:58 PM
non-VTEC's Avatar
is your kpro properly setup to run the 3 bar sensor?
you cant just hook it up and expect it to work.....
Old May 10, 2005 | 03:36 PM
alpha's Avatar
Default Re: 3 bar GM map sensor trouble (non-VTEC)
Yes his KPro is properly setup for his three bar I would hope so being the boost gauge usually says 20 PSI at WOT
Alberto, like I said on the phone I am 99% sure it's the map sensor.
Old May 10, 2005 | 05:50 PM
Emshhh's Avatar
You can test the voltages of the 3bar to make sure it's sending out proper signal.
should read 1.6v from the map to the gnd wires.
Old May 27, 2005 | 06:10 PM
dategb16vortech's Avatar
Default Re: (iGfrequency)
can you run a 3 bar map with a hondata s200b on a p28 ecu or does something need to be burned into the ecu to make it run properly
Old May 27, 2005 | 06:14 PM
mtber's Avatar
Default Re: (dategb16vortech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dategb16vortech &raquo;</TD></TR><TR><TD CLASS="quote">can you run a 3 bar map with a hondata s200b on a p28 ecu or does something need to be burned into the ecu to make it run properly</TD></TR></TABLE>
The eprom must be setup to work with the map sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iGfrequency &raquo;</TD></TR><TR><TD CLASS="quote">You can test the voltages of the 3bar to make sure it's sending out proper signal.
should read 1.6v from the map to the gnd wires. </TD></TR></TABLE>
+1 check the sensor voltage.
Old May 27, 2005 | 07:43 PM
HiProfile's Avatar
Take it up near WOT (low vacuum/boost) and it should run fine. The problem with the 3-bar, which is plauging uberdata users mostly, is that the GM bar sensor's real reading in high-vacuum are totally off (non-linear) compaired to the datasheet. IIRC, -22 in/Hg is read/output as -27 in/Hg. I bet if you stuck a wideband in and tested it, it'd idle very rich. Rich + added throttle = more gas injected, resulting in stalling/hesitation.
And FYI, the only GM 3-bar sensor that won't function like this...is a fualty one.
edit - and before I forget, the GM 3-bar also tends to give strange readings above 22psi according to most users.
sdbee84
Jan 31, 2016 11:20 AM
h22sedan
Dec 3, 2006 07:46 PM
zbower7
Jun 21, 2004 08:42 PM
CiViC SiR
Jul 7, 2003 02:22 PM
