strange problem please look!!
Old May 8, 2005 | 08:08 PM
B20luda's Avatar
Default strange problem please look!!
motor is a b20a5 ( 90prelude motor) built forged pistons crower rods total seal gapless rings honda bearings built head rev valves, springs, and retianers ported polished new guides and vavle seals..engine has about 600 miles on it...smokes some blue after reving at idle ...pull the plugs and u can see fluid sitting in the cylinder ( number 1) the rest are just wet looking...its not fuel and its not coolant..it feels like oil but where is it coming from and how is that much oil gettin into the combustion chamber and just sittin on top of the piston...werid thing is that the plugs dont look oily they are semi dark but not oily what so ever..i did a leakdown test and that came back ok...any ideas anyone please help want to get this thing boostin again.. thanks Mitch
BTW i know it sounds like a valve seal problem but those are new just replaced...and there installed right...
Modified by B20luda at 8:38 PM 5/8/2005
Old May 8, 2005 | 09:52 PM
crucian's Avatar
Default Re: strange problem please look!! (B20luda)
how cvan you be sure that the valve seals are installed right. My biddy has the same problem with his motor. After replacing the valve seals with new ones, motor smokes.
Old May 8, 2005 | 09:56 PM
B20luda's Avatar
Default Re: strange problem please look!! (crucian)
well i have replaced them twice..i thought it was the problem the first time..i dont see how they are failing again..
Old May 9, 2005 | 10:08 AM
B20luda's Avatar
bump it up..common guys nothin??
g2turbo
Apr 13, 2020 10:36 AM
eriki
May 9, 2013 03:14 PM
Poordudes TypeR
Sep 13, 2011 09:22 PM
si 2
May 8, 2010 10:16 AM
1fastlude1
Apr 2, 2008 05:37 AM
