d15b vtec engine
I have a problem with my rps, they are jumping up and down in between
900-1,500 rps when i come to a full stop. the only modification that i did was a
OBX performance cam (for turbo), and a Y8 manifold, and the Y8 fuel rail. I try retarding the timing and advancing it. but is the same thing I check all the vaccum hoses and idle mixture connection and adjustments but is the same
so i have no clue, please help...
when you put that Y8 manifold on did you reuse the gasket?
soundsl ike a vacuum leak to me,
and considering you swapped intake manis that would make perfect sense.
get a new gasket on there, and make sure theres no old gasket stuck on, and that you didnt scratch it badly scraping the old one off.
AllmotorGSReg
20
Apr 12, 2013 05:57 PM
MildWater
21
Mar 7, 2007 12:27 AM
foesicks
Dec 5, 2002 10:35 AM
