Cam timing issue
Old May 8, 2005 | 01:06 PM
94turboD's Avatar
Default Cam timing issue
I have a crower stage 1 cam in my d16z6 turbo. Currently my timing is advanced 22 degrees, its advanced that far because at this setting the car was stalling out at idle on the stock timing settings. I was wondering if anyone is using the same cam with your turbo set and what your timing is set at.
oh if this helps, my set up is, 92-95 greddy turbo kit, using the blue box for fuel management, a dsm side mount intercooler and turbo xs type s bov. I'm boosting at 8 lbs.
Modified by 94turboD at 2:32 PM 5/8/2005
Old May 8, 2005 | 01:35 PM
NJIN BUILDR's Avatar
Default Re: Cam timing issue (94turboD)
Do you mean your cam timing or ignition timing is 22 deg advanced.These are to different things.If you cam timing is that far advanced and it runs then you are measuring something wrong.
Glenn
Old May 8, 2005 | 02:36 PM
SpeedDreamz.com's Avatar
Default Re: Cam timing issue (NJIN BUILDR)
I believe he means ignition timing. Most cam gears only give 8-10.,
Old May 8, 2005 | 03:03 PM
94turboD's Avatar
Default Re: Cam timing issue (SpeedDreamz.com)
Yeah, its the ignition timing is advanced 22 degrees.
kirkland08
Feb 13, 2011 08:59 AM
has-t
Jul 1, 2003 09:58 AM
Jockobo
Jan 23, 2003 03:48 PM
redcxhatch
Nov 16, 2002 08:04 AM
