intercooler mounting...
Old May 11, 2005 | 08:30 AM
BDaTurboTeg's Avatar
Default intercooler mounting...
any show me how they have there intercoolers mounted?
i need to figure out the best way to mount mine...so ideas are welcome...
Old May 11, 2005 | 07:54 PM
Default Re: intercooler mounting... (BDaTurboTeg)
bump
Old May 11, 2005 | 08:57 PM
.dave's Avatar
i HAS questions ?
Its hard to see, but I put the intercooler up against the car and marked it where there are already two large holes through the lower core support. I had two aluminum L shaped tabs welded onto the bottom and one on the top. The top one didn't line up so well, but the bottom too lined up perfectly. I then got some big *** stainless steel bolts, washers, and nuts and bolted it up. Its not going anywhere, you can stand on the damn thing.
Old May 11, 2005 | 09:09 PM
buck02's Avatar
Default Re: intercooler mounting... (1 cam)
this is my new line of intercoolers with tabs mounted here check them out
or check out the sizes i offer on my web sight
http://www.blmotorsports.com
Old May 11, 2005 | 09:53 PM
Treblarefils's Avatar
I used 2 long *** bolts with nuts that have star washers. Drilled through bumper support and screwed it on. I cut off the excess bolt that was sticking out to leave it flush its very clean looking and the intercooler will not go anywhere.
Old May 11, 2005 | 10:22 PM
This One's Avatar
Default Re: intercooler mounting... (buck02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 &raquo;</TD></TR><TR><TD CLASS="quote">this is my new line of intercoolers with tabs mounted here check them out
heh, we using similiar stuff.
mounted like so...
Old May 11, 2005 | 10:34 PM
SSBPGSR's Avatar
Default Re: intercooler mounting... (This One)
^^ pretty nifty
Old May 11, 2005 | 11:02 PM
Rod.'s Avatar
Default Re: intercooler mounting... (SSBPGSR)
nice intercooler buck
Old May 12, 2005 | 04:42 AM
nice guys......now...lol any with a backdoor style intercooler? because thats what i got and its kinda buggin me on how i should mount this thing..
Old May 12, 2005 | 05:06 AM
meanB6teen's Avatar
Well i bought a precision without tabs i guess i can pick some tabs up from like home depot and get them welded on?
Old May 12, 2005 | 07:55 AM
SSBPGSR's Avatar
Default Re: intercooler mounting... (meanB6teen)
i went through the same thing with precision, home depot does not have the L shaped brackets you need. they need to be aluminum ( you cant weld steel to aluminum ) i had a write up on how to do this with a precision but the pics dont work anymore, so the thread is now worthless.
Old May 12, 2005 | 08:03 AM
meanB6teen's Avatar
Well Im putting my kit on at the end of may maybe you can IM or PM me or something so i can get this done before the day comes
Old May 12, 2005 | 08:17 AM
1158's Avatar
My intercooler, pictured above, has a tab on each side above the inlet piping. Could I drill a hole in that and then bolt the bracket to it? For the bottom I was thinking of using something similar to a lower mount for a radiatior (with some insulation to prevent damage to the intercooler). Would these ideas work?
Modified by 1158 at 6:43 PM 5/12/2005
Old May 12, 2005 | 08:59 AM
TurboGoKart's Avatar
Default Re: intercooler mounting... (1158)
Yeah you can do that. Just make sure you dont puncture the end tanks.
It's really anything goes as far as hanging intercoolers goes. My first IC we just hung with thick zip ties. Anything will work. Your IC pipes will help hold the IC up and tight also.
Old May 12, 2005 | 02:27 PM
turbodohcsi's Avatar
big *** zip ties
Old May 12, 2005 | 07:57 PM
speeddave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 &raquo;</TD></TR><TR><TD CLASS="quote">this is my new line of intercoolers with tabs mounted here check </TD></TR></TABLE>
sorry for OT question, but how are those coolers anyway? anybody using them?
Old May 12, 2005 | 09:39 PM
DRIVENRacing's Avatar
seen a few... not with a lot of boost... ^^
Old May 13, 2005 | 02:31 AM
someday's Avatar
Default Re: intercooler mounting... (speeddave)
if buck offers it, its a good product email him and see.
Old May 13, 2005 | 08:04 AM
mrbsponge's Avatar
i have the same core as the "buck 02 " model, its damn near the same, except mine has a bolt in the dead center, and i removed the bumper cover bolt thingy, and ran a bolt down to the intercooler
and i used the tabs on the bottom to the front end support
Old May 13, 2005 | 12:33 PM
speeddave's Avatar
Default Re: (mrbsponge)
i'll see what buck has to say about them, thanks guys.
lscivic8.5
Aug 21, 2007 04:44 PM
redboost10
Aug 2, 2006 08:50 AM
turbo gsr
Jun 20, 2006 03:03 PM
Rain_man
Apr 20, 2003 11:33 PM
88crxvtec
Apr 8, 2003 08:41 AM
