who's not running a flexpipe on your FI exhaust.?
Re: who's not running a flexpipe on your FI exhaust.? (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote">no flex, just 2.5" steel downpipe</TD></TR></TABLE>
same
same
Re: who's not running a flexpipe on your FI exhaust.? (BlackCRX)
Unless you have really stiff motor mounts, you should run a flex section. It puts alot on stress on the turbo/manifold if you don't.
Re: who's not running a flexpipe on your FI exhaust.? (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">Unless you have really stiff motor mounts, you should run a flex section. It puts alot on stress on the turbo/manifold if you don't.
</TD></TR></TABLE> i have a t-25 on a hf mani do you think that is big/heavy enough to cause stress? (i have stock mounts and have not noticed a prob yet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> i have a t-25 on a hf mani do you think that is big/heavy enough to cause stress? (i have stock mounts and have not noticed a prob yet)</TD></TR></TABLE>
Its not the weight from the turbo, when there is no flex section and the motor is rocking back and forth, the turbo, manifold and downpipe are trying to "bend" the exhaust right behind the oil pan, sort of like a pivot point.
If you don't have a flex, its trying to lift the entire weight of the exhaust, when there is a flex, it enables it to give at that critical point.
Re: who's not running a flexpipe on your FI exhaust.? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">my revhard manifold cracked after only 2000 miles. I think it was because I wasnt using a flexpipe, only a ball and socket joint that may not have been sufficient.</TD></TR></TABLE>
Same with mine. I'm using solid motor mount's now..
i didnt use a flex section on my ITR. i had stiff *** mounts and ran rubber hangers and used V band. So I guess that all helped it
The ball and socket joint has to actually function (i.e. move when it needs to), and has to be located in the correct spot (mine is where the stock one used to be), my setup has over 40K on it, no issues.
Re: who's not running a flexpipe on your FI exhaust.? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">hello everybody.
who's not running a flexpipe on DP\exhaust?
and why?
best regards moshik galimidi
no flexpipe, but i run tension spring bolts where dp connects to cat converter, just like you would have factory
and why?
Re: who's not running a flexpipe on your FI exhaust.? (vtec.dc2)
i ran no flex pipe on my drag kit and a few runs on the twistys led me to a cracked down pipe. i fixed it and a few weeks later it cracked for a 2nd time this time in a different spot. I used the factory style spring bolts and donut for all of that. I switched to a flex pipe since and have been running the twistys for over a year now and no cracks. i vote flex pipe
If you don't have a flex, its trying to lift the entire weight of the exhaust, when there is a flex, it enables it to give at that critical point. </TD></TR></TABLE> ok thanks for the info
Re: who's not running a flexpipe on your FI exhaust.? (itr206)
i just mocked up my dp with my arc welder, im gonna mig it tomorrow at work. im gonna run a 90deg from the flange and about a 3" of stright pipe and another 90deg and about a 7" of flex pipe,
pics tomorow
pics tomorow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote"> i suck dick. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Dude seriously , WTF is your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">Dude seriously , WTF is your problem. </TD></TR></TABLE>
lol... Flexpipe
lol... Flexpipe
I didn't run one for about half a year. I kept getting exhaust manifold gasket leaks and the turbo manifold kept getting loose. After I got a flex pipe all that went away.
wfocrx
14
10-31-2007 01:17 AM
SolAssassin
06-20-2006 08:18 PM
