Spark plug gap?
Old May 9, 2005 | 06:19 AM
ginoboy1978's Avatar
Default Spark plug gap?
Hey guys,
I have d16y8 turbo'd, 9.6:1 compression, 7lbs of boost with ngk bkr7e plugs gapped @ .030.
My car has been tuned... When my car is idleing(@ 900rpms) sometimes it starts to go down and then it dies(unless i push on the gas pedal). I'm going to adjust my plug gap to .035-.037.....i think mine gap is too tight right now.
NGK says for every 50hp should lower gap by .004.
I think this will help my car when idleing....just want to see if anyone has experienced this.
Thanks.
DAN
Old May 9, 2005 | 06:54 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Spark plug gap? (ginoboy1978)
That will NOT help your idle.
You need to get your tuner to fix that. Proly IAC issue. What EMS are you running?
.37 is too large of a gap with the stock ignition system and you could end up blowing out the spark.
Old May 9, 2005 | 06:59 AM
Evanmb44's Avatar
you are contradicting yourself when you say you are going to adjust to .035 when you said NGK says to lower it. lowering the gap means lowering the number. your plugs should be gapped to .028-.032 inches
like white smoke said, your idle is bad because of something else
Old May 9, 2005 | 07:01 AM
Default Re: (Turboaddict)
No when i said lowering it......i meant lowering it from the stock setting of .044(1.1mm)...sorry to be unclear.
DAN
Old May 9, 2005 | 07:30 AM
Evanmb44's Avatar
Default Re: (ginoboy1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">No when i said lowering it......i meant lowering it from the stock setting of .044(1.1mm)...sorry to be unclear.
DAN</TD></TR></TABLE>
i see. well just gap them to .028-.030
Old May 9, 2005 | 07:34 AM
Thats what they are at now (.030) i'm gonna raise it to .035.
DAN
Old May 9, 2005 | 08:19 AM
i my honda
Global Mod
Not listening...
That’s why you take you car to a tuner and are not doing it yourself.
Its not going to change you idle bro. But what do I know
Old May 9, 2005 | 05:12 PM
Default Re: (White Smoke)
I increased my gap to .035.......i drove it around for an 30 mins.....let it idle for 10 mins........no more problems.
My car idles like a million bucks(just like stock). Also car starts up right away after it's been driven for a while......usually would have to crank it 5 times and push down the peddle to get it going. Now i just turn the key and it starts perfectly....and idles perfectly.
I'm happy
Peace.
Old May 9, 2005 | 06:07 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
hahaha the noob knows more than you guys!!!!!! j/k
Old May 10, 2005 | 04:53 AM
Default Re: (h22boy)
Well thanks for all your advice......but for now the car idles great.
Take care guys.
DAN
Old May 24, 2005 | 08:03 AM
crucian's Avatar
Damn, that's fucked up bro. noob owns you!
Old Jan 14, 2006 | 07:36 AM
PA MATT's Avatar
Default Re: (crucian)
i had the same thing happen to me. I was runnin about .028 and it idled like ****. Changed it to stock gap and runs fine now
wtsapexipowerfc
Sep 18, 2010 01:37 AM
pa2play
Jul 25, 2004 01:15 PM
2000fbp
Sep 25, 2003 10:03 AM
t616
Sep 22, 2003 07:42 PM
Casey
Mar 19, 2002 07:00 PM
