CHECK VALVES
OK I have purchased check valves to temporarily get the map sensor code off my ecu. I have ordered an safc to do that also. How and where do I hook up the check valves on the manifold? Is it the line that runs from the I M to the Blow off valve...? any help thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennyhonda7 »</TD></TR><TR><TD CLASS="quote">as in the aquarium...and one other question when i install the safc I will no longer need them correct?</TD></TR></TABLE> correct, also i would skip the safc and go turbo-edit or uberdata (depending on what obd you have)
I do have uberdata but do not know how to use it...the ecu i have in the car has uberdata but i do not have the program...it has a rich base map...already what do i need to tune uberdata? Also will the safc or uberdata allow me to get close to passing emissions test? with the uberdata on now i still had the map cel...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennyhonda7 »</TD></TR><TR><TD CLASS="quote">I do have uberdata but do not know how to use it...the ecu i have in the car has uberdata but i do not have the program...it has a rich base map...already what do i need to tune uberdata? Also will the safc or uberdata allow me to get close to passing emissions test? with the uberdata on now i still had the map cel...</TD></TR></TABLE> as far as emissions go...i dont know for your state but in cali you will fail with a turbo(unless you have a carb sticker) and as far as tuning goes talk to my buddy xencron(he's here on h-t) he will tell you everything you need to know(let him know i sent you his way)
hey i just saw that your a "noob" so you dont have om's yet and can only post 5 a day so if you want to reach him go to his site: http://www.xenocron.com or you can find him on http://www.homemadeturbo.com (under the same screen name) and you wont have the 5 post rule on hmt (i hope that helps)
