Can someone explain how a diff wastegate spring makes a diff?
Old May 7, 2005 | 06:24 PM
Bimmerman's Avatar
Default Can someone explain how a diff wastegate spring makes a diff?
example 4lb verus 8lb? I am going to be putting on my kit soon and will be running 10 psi, what should my wWG spring be and why?
Old May 7, 2005 | 06:45 PM
SDT Project EF's Avatar
Default Re: Can someone explain how a diff wastegate spring makes a diff? (Bimmerman)
diff spring rates have different tension. the higher the tension is and the bigger the spring is. the more its gonna hold the valve. down. thus creating more boost pressure. general rule of thumb is you can saftley exceed your spring by double. so if your spring is 5 psi. the max you should safely go is 10 psi. so as the wastegate deosnt creep/spike
pcguy760
Jul 8, 2011 09:08 AM
turbo-crx
Apr 1, 2009 11:42 AM
NORCALCVC
Feb 15, 2005 11:57 PM
Short Round
Nov 12, 2003 10:16 PM
X2BOARD
Jun 4, 2002 08:20 AM
