loud ticking...
Old May 7, 2005 | 09:45 PM
mike93eh
Guest
Posts: n/a
Default loud ticking...
since ive installed my turbo, i have gotten a really loud ticking noise. my engine is in perfect condition. timing is dead on and valve adjustment is dead on. but i hear this loud ticking noise, everybody asks me about it, heh. now i know honda engines like to tick a little, but mine is a little loud. my car runs great and the head is flawless. i have checked all the valves, springs, etc..
Old May 7, 2005 | 09:50 PM
B18C1CYA's Avatar
Default Re: loud ticking... (mike93eh)
describe this tick ?? is it a tick or knock ???
Old May 7, 2005 | 11:27 PM
DRIVENRacing's Avatar
Default Re: loud ticking... (B18C1CYA)
is it wot or partial?
Old May 8, 2005 | 04:53 AM
nsxmatt's Avatar
Sounds like a exhaust gasket is leaking maybe.
Old May 8, 2005 | 06:00 AM
mike93eh
Guest
Posts: n/a
Default Re: loud ticking... (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">is it wot or partial?
its ticks all the time. from idle up to wot..
tick or knock? i would say tick..
Old May 8, 2005 | 06:03 AM
Boosted2K's Avatar
What kind of manifold are you running??
I konw that switching out a cast manifold (stock header or turbo) to a tubular design will amplify the normal valvetrain chatter
Old May 8, 2005 | 11:16 AM
mike93eh
Guest
Posts: n/a
i have the greddy turbo kit. so it has a cast manifold.
Old May 8, 2005 | 11:18 AM
SOHC_MShue's Avatar
Default Re: (mike93eh)
what injectors? DSM 450's tick loud.
Old May 8, 2005 | 11:24 AM
null.'s Avatar
Default Re: (SOHC_MShue)
injectors maybe your culprit
Old May 8, 2005 | 11:27 AM
SOHC_MShue's Avatar
Default Re: (eg6junkie)
Yea man I had thought I had a loud ticking coming from my motor too. I listened around and it wasn't coming from the block and definintly not from the head either(which also ticks loud from my zex cam, but it wasn't the same sound). Then I listened towards the back of the engine and it definintly was coming from my dsm's.
Old May 8, 2005 | 11:28 AM
adseguy's Avatar
yeah i noticed the injectors were loud when i did my turbo (DSM 450's)
can you take a shirt video of it with a digital video camera or somehow get us the sound? I can host it if you want
Old May 8, 2005 | 11:38 AM
beepy's Avatar
Default Re: (adseguy)
I have a ticking driving me nuts on my car. Turns out to be a small crack on the underside of one of my primary tubes. It actually only ticks at idle and when accellerating, it goes away when cruising, because I guess the scavenging is pulling gas in instead of pushing it out?
Old May 8, 2005 | 11:52 AM
SOHC_MShue's Avatar
Default Re: (beepy)
http://www.we-todd-did-racing....DE%3D
here is an old vid of my engine if you want to compare it to your ticking. Just to let you guys know my car is super loud from the zex cam as well so don't think that my valves are messed up or something .
Old May 8, 2005 | 12:01 PM
dornon13's Avatar
i think its an exhaust leak also...i blew out my gasket between my tial wastegate and the manifold and it ticked pretty loud pretty scary it happened the firt night i had it turbo'd i didnt figure it out till a couple days later...anyways my injectors tick pretty loud too i have tunertoys injectors..
Old May 8, 2005 | 01:17 PM
null.'s Avatar
Default Re: (dornon13)
you can try to put a screwdriver against the injectors to hear if it iis really the injectors
Old May 8, 2005 | 02:21 PM
crucian's Avatar
It sounds like your valves are tapping to me. Do a search for "vavle tap". Maybe that should help you out a little more. I just rebuilt my motor and it is making the same tapping noise. The cam might be making it tap like that also. Try doing 2 more valve adjustments. But I think if you have a HP cam in, it's going to tap.
Old May 8, 2005 | 03:28 PM
WhitEdRift's Avatar
Default Re: loud ticking... (crucian)
Timing belt? Mine does that like mad. Been slapping for like a year. Don't have turbo though....
Old May 8, 2005 | 03:49 PM
utahbmx's Avatar
My last "tick" I thought was the valves but it ended up being a spun rod bearing.
Old May 8, 2005 | 04:07 PM
mike93eh
Guest
Posts: n/a
Default Re: (utahbmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by utahbmx &raquo;</TD></TR><TR><TD CLASS="quote">My last "tick" I thought was the valves but it ended up being a spun rod bearing. </TD></TR></TABLE>
ahh dont scare me like that.
i have stock injectors and cam so its not that. and besides the noise is most audible from the front of the engine/manifold area. ive already rebuilt my head and did 2 valve adjustments. it was making the ticking noise before i did that. it started doing it once i put my turbo on. im also thinking it has to be exhaust leak. ive noticed that the surfaces on the manifold for the exhaust chamber and the greddy gaskets wherent the best. the surface wasnt perfectly straight. i believe if i remember right i had a VERY VERY small gap. have to check it out.
Old May 8, 2005 | 04:29 PM
ramennoodles's Avatar
dsm's tick pretty loud. my car was quiet until i put the injectors in. sounds just like valves ticking, probably louder than valves
Old May 8, 2005 | 05:52 PM
dornon13's Avatar
Default Re: (ramennoodles)
start it up and kinda put your hand down there see if you feel air rushing...and after a while it will get black around it so that will help if its a leak...
Old May 8, 2005 | 06:50 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">start it up and kinda put your hand down there see if you feel air rushing...and after a while it will get black around it so that will help if its a leak...</TD></TR></TABLE>
well yea thats obvious but if ti was leaking it would also be loud as hell right there. so loud i wouldnt of even heard the ticking.
Old May 8, 2005 | 07:17 PM
SOHC_MShue's Avatar
what exactly does a spun rod bearing tick sound like? How long does the motor normally last after spinning a rod bearing with the usual beating on the engine?
Old May 9, 2005 | 01:54 AM
dornon13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">
well yea thats obvious but if ti was leaking it would also be loud as hell right there. so loud i wouldnt of even heard the ticking.</TD></TR></TABLE>
Huh?? an exhaust leak will sound like a tick i dont get what youre saying
Old May 9, 2005 | 02:20 PM
mike93eh
Guest
Posts: n/a
Huh?? an exhaust leak will sound like a tick i dont get what youre saying</TD></TR></TABLE>
yea i guess maybe a pinhole sized one. i dunno a exhaust leak to me sounds like chopping the muffler off your car.
