GSR and LS Motor: IC Piping the same?
Old May 11, 2005 | 09:09 AM
TURBO DC2's Avatar
Default GSR and LS Motor: IC Piping the same?
Vehicle: 94-01 GSR
Will intercooler piping from an LS motor in a DC2 fit on a DC2 GSR? If not what modifications will be required?
Old May 11, 2005 | 09:10 AM
Makdaddynuge's Avatar
Does the gsr have the stock intake manifold? If so, the piping that connects to the intake manifold will not work out, everything else should.
Old May 11, 2005 | 10:32 AM
TURBO DC2's Avatar
Default Re: (Makdaddynuge)
ya its a stock manifold. but I think the GSR mani is flipped.
Old May 11, 2005 | 10:34 AM
Ben Huynh's Avatar
Default Re: (slammed_gsr)
You'll need a GS-R upper charge pipe.
Old May 11, 2005 | 10:43 AM
TURBO DC2's Avatar
Default Re: (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">You'll need a GS-R upper charge pipe.</TD></TR></TABLE>
Ok thanks guys
Old May 11, 2005 | 10:54 AM
Pnoyej6's Avatar
* B A N N E D *
I HAVE QUESTION SIMILAR TO POST
WILL THE LS GREDDY INTERCOOLING PIPING BOLT ON TO A 00 GSR WITH SKUNK 2 INTAKE MANIFOLD???
Old May 11, 2005 | 11:00 AM
1158's Avatar
Default Re: (pnoytegn707)
The Ls/Type R piping will work with any Type R style manifold on a GSR. So yes, that will work.
Old May 11, 2005 | 11:23 AM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (1158)
SO THE LS INTERCOOLING PIPING AND CHARGE PIPE SHOULD BOLT ON PERFECTLY WITH MY GSR WITH SKUNK 2 INTAKE MANI. HOW BOUT THE GREDDY DOWNPIPE WILL IT BOLT ON. I HAVE 00 GSR. I BELIEVE 94-00 LS DOWNPIPE AND 00-01 GSR DOWNPIPE ARE SAME LENGTH. CORRECT ME IF IM WRONG.
Old May 11, 2005 | 12:25 PM
spoolingb20's Avatar
You should invest in a upgraded mani you will deff want it for the long run and then purchass your pipping according to what you go with. From exp if you do upgrade i wouldnt use the skunk.
Luke G.
Jan 23, 2010 04:53 PM
adhana2
Mar 14, 2007 10:06 PM
Accurate GS-R
Jul 23, 2004 06:14 PM
b18cEF9
May 13, 2004 10:08 AM
Mr. Softee
Jun 6, 2002 01:54 PM
