OEM D series Pistons and rods for forced induction?
Ok I know the weakness on a D series are the Rods, but how about the pistons?. How much whp can stock pistons handle before they go out. Im planning on doing a build in the near future to bump up the boost on my D series turbo. I know for sure I am getting Eagle rods but I have not heard of anyone complaining about the pistons. Can the pistons them selves handle 250whp. Im sure my goal is a bit lower then that but I want to keep it on the safe side of things, and don't want my engine to take a dump while Im cruising around. Im sure with proper tuning the pistons and rods can handle my goals but like I said I want to be on the safe side of things.
Re: OEM D series Pistons and rods for forced induction? (EK-TSOHCV-TechRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TSOHCV-TechRider »</TD></TR><TR><TD CLASS="quote">Ok I know the weakness on a D series are the Rods, but how about the pistons?. How much whp can stock pistons handle before they go out. Im planning on doing a build in the near future to bump up the boost on my D series turbo. I know for sure I am getting Eagle rods but I have not heard of anyone complaining about the pistons. Can the pistons them selves handle 250whp. Im sure my goal is a bit lower then that but I want to keep it on the safe side of things, and don't want my engine to take a dump while Im cruising around. Im sure with proper tuning the pistons and rods can handle my goals but like I said I want to be on the safe side of things.</TD></TR></TABLE>
all honda cast pistons are crap. weak ringlands.
Re: OEM D series Pistons and rods for forced induction? (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">Pistons are crap Highest i've seen on stock internals was 300whp.
SIG:D-Series Turbo Ninja!
Turbo D16z6 Del sol SI @ ~9.5psi D16z6
14.1@102 mph (uberdata EMS)
Whats your setup. Are you using aftermarket rods and pistons and how much whp are you making?
if you wanna run some vitara pistons, i have a set i need to get rid of. check my post.
https://honda-tech.com/zerothread?id=1241127
just in case u were thinking of using aftermarket rods on stock pistons
u cant
stock pistons are pressed wrist pins
aftermarket pistons are floaters
cant use aftermarket rods on stock pistons
u cant
ninesecrx
04-18-2005 02:57 PM
