Boosted B18B: How much Torque?
Old Aug 23, 2005 | 12:50 PM
Civic Hx-T's Avatar
Default Boosted B18B: How much Torque?
Anyone have supporting Dynos for torque around 8psi daily on stock internals and maybe AFC fuel management or something similar?
Old Aug 23, 2005 | 01:04 PM
Civic Hx-T's Avatar
Only Dyno I've seen was pretty.. .uhh... "neat".
144who
140tq
I guess I thought that LS motors would put up more tq than whp.
Old Aug 23, 2005 | 01:14 PM
wutupnut's Avatar
Default Re: (Civic Hx-T)
I hit 199 which peaked at 5600 rpm on my Ls/Vtec at 8psi
Old Aug 23, 2005 | 01:15 PM
Civic Hx-T's Avatar
Ah crud. That's LS/VTEC. Thanks for the info though.
Looking for straight/stock B18b/LS
Old Aug 23, 2005 | 01:40 PM
wisjdmhonda's Avatar
check sig
Old Aug 23, 2005 | 02:02 PM
Reason's Avatar
Default Re: (wisjdmhonda)
check out the link in my sig
Old Aug 23, 2005 | 06:35 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">check sig</TD></TR></TABLE>
same here. and to defend myself- my timing is very conservative
Old Aug 23, 2005 | 07:19 PM
DENCIO's Avatar
Default Re: (blackeg)
&lt;&lt;---208whp 197tq @8psi...t3/t04e 57 trim..bone stock LS
DENCIO's Avatar
Old Aug 23, 2005 | 09:03 PM
Sohc Driver's Avatar
Default Re: (DENCIO)
I put out 206wtq on 8psi with by bone stock straight LS. Running Hondata s200b though
Khoi
Old Aug 24, 2005 | 08:57 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Sohc Driver)
i was at 9.5 psi
225ft lbs stock LS
Old Aug 24, 2005 | 11:57 AM
Dunc's Avatar
BCICAN
Default Re: (Snoflake)
roughly 250-260wtq at 15psi but that's with ls/vtec
Old Aug 24, 2005 | 11:59 AM
roydogg's Avatar
Default Re: (Dunc)
254whp & 249wtq @15psi
Old Oct 10, 2005 | 08:05 PM
Vp Special K's Avatar
Default Re: (roydogg)
239whp & 220tq t3/to4e 54 trim .48 ar @ 8.5psi stock LS neptuned
Old Oct 10, 2005 | 08:10 PM
xerox445's Avatar
Default Re: (Vp Special K)
Username Sean put down 300whp and 290 torque on 14 or 15 psi, stock ls block, sc61
Old Oct 10, 2005 | 08:29 PM
blown_LS's Avatar
Default Re: (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">Username Sean put down 300whp and 290 torque on 14 or 15 psi, stock ls block, sc61 </TD></TR></TABLE>
Usually small turbos make pretty good tq but that is impressive right there. Where did you make your peak tq though?
Old Oct 10, 2005 | 09:31 PM
adseguy's Avatar
Default Re: (blown_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blown_LS &raquo;</TD></TR><TR><TD CLASS="quote">
Usually small turbos make pretty good tq but that is impressive right there. Where did you make your peak tq though?</TD></TR></TABLE>
yeah probably with a powerband of 1k rpm
328whp/268trq - 16PSI - stock block
Why do you want to know aobut torque anways? Honda motors are not made to build torque. They are made to rev high and create horsepower, not so much torque
Old Oct 10, 2005 | 10:23 PM
JDM EJ1 95's Avatar
245whp and 225 ft lbs @ 12 psi here
b18_eg
Jan 24, 2008 03:34 PM
juanintec
Oct 16, 2007 03:57 AM
AZNracerx1989
Nov 27, 2005 08:01 PM
six7one
Apr 11, 2005 03:53 AM
turbols619
Dec 28, 2004 04:12 AM
