d16y5 and boost (fuel management)
Old Aug 20, 2005 | 06:55 PM
brent_G's Avatar
Default d16y5 and boost (fuel management)
What are the options for fuel management for the y5?
I tried searching... but its down right now.
Can you convert to obd1 and run a socketed p28 and run crome/uberdata?
Old Aug 20, 2005 | 07:11 PM
93turbo16's Avatar
Default Re: d16y5 and boost (brent_G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G &raquo;</TD></TR><TR><TD CLASS="quote">
Can you convert to obd1 and run a socketed p28 and run crome/uberdata? </TD></TR></TABLE>
That is your best option. I can help you out with supplying the ecu if you are interested.
Old Aug 20, 2005 | 07:12 PM
jolt-tsp's Avatar
yes.
Old Aug 20, 2005 | 07:17 PM
brent_G's Avatar
Default Re: d16y5 and boost (jolt-tsp)
Ok good. thats what i was planning on doing..
What would you do about the vtec e?
Old Aug 21, 2005 | 04:47 PM
brent_G's Avatar
has anyone done it before?
Old Aug 21, 2005 | 04:51 PM
N20civicB18's Avatar
dont those have a oem 5 wire o2? that might cause problems running a p28
Old Aug 21, 2005 | 07:01 PM
NIGHTRIDER27's Avatar
Default Re: d16y5 and boost (93turbo16)
hey i got a 97 civic dx tonight we jsut got done with the whole turbo set up we up a ex intake manifold on it ex injectors for now waiting for upgreaded ones and the guy i was trying to get a chipped p28 ecu form keeps pushhing the date further and further i read that u got what i need ?? i run 7lbs boost i for get what injectors i ordered at the moment umm yeah let me know
Old Aug 21, 2005 | 08:17 PM
brent_G's Avatar
Default Re: d16y5 and boost (NIGHTRIDER27)
see iw as plannin on runnin the 450s and a street tuning... But since the y5 head is all wack with roller rockers or whatever i didnt know if it would work like "normal".
Or do you have to swap the head out for y8 ..
thats basically the question
Old Aug 22, 2005 | 04:45 AM
jolt-tsp's Avatar
I'm running a y5 with 450's and a chipped p28 right now (tuned with uberdata). The only issue you'll run into is passing emissions, but it may not be a problem in your area. The only problem with the y5 is camshaft availability. I don't believe other D-series cams will work, but I haven't tried it. I think the y5 head is probably the most underrated head honda makes.. but I'm biased
Old Aug 22, 2005 | 06:02 AM
brent_G's Avatar
so you had no problem running uberdata? did you have to modify the 5 wire?
Can you explain your setup better to me?
Old Aug 22, 2005 | 07:19 AM
tilt's Avatar
no problems running uberdata. You have to either convert 5-wire to 4-wire narrowband or just run open loop and disconnect the o2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G &raquo;</TD></TR><TR><TD CLASS="quote">so you had no problem running uberdata? did you have to modify the 5 wire?
Can you explain your setup better to me? </TD></TR></TABLE>
Old Aug 22, 2005 | 07:26 AM
specv5150's Avatar
Default Re: d16y5 and boost (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">no problems running uberdata. You have to either convert 5-wire to 4-wire narrowband or just run open loop and disconnect the o2.
I did a write up on converting the Y5 to 4wire. I think the P28 really livens up the Y5. I am going to set my vtec xover to 2000 or so like stock and see what happens. My car feels "laggy" before vtec now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G &raquo;</TD></TR><TR><TD CLASS="quote">see iw as plannin on runnin the 450s and a street tuning... But since the y5 head is all wack with roller rockers or whatever i didnt know if it would work like "normal".
thats basically the question </TD></TR></TABLE>
I have ran uberdata and the afc hack on ym Y5 with 450's and it works great. With the hack, I had to adjust the timing by the dizzy but I think all afc hack people need to do that. The Y5 is just not as known nor does it have the vast aftermarket of the other popular D series swaps but other than that it works on teh same principles as far as turboing it goes
Old Aug 22, 2005 | 10:21 AM
brent_G's Avatar
Default Re: d16y5 and boost (specv5150)
alright thats some reassuring info. Ill be looking for a conversion harness and a p28 here now.
Old Aug 22, 2005 | 10:26 AM
brent_G's Avatar
What if you used a vx base map.. ? that runs off the same 5 wire.
Old Aug 22, 2005 | 10:36 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G &raquo;</TD></TR><TR><TD CLASS="quote">What if you used a vx base map.. ? that runs off the same 5 wire. </TD></TR></TABLE>
I looked into but someone on here who chips ECU's said it isnt possible for some reason. Besides, the OBD1 VX ECU cant be chipped because I thoguth of running the oBD1 VX with an uberdata chip but the same guy said it wasnt possible. My car runs great on a P28 basemap
Old Aug 22, 2005 | 10:38 AM
brent_G's Avatar
alright. wonderful thanks for your help.
Feel free to add any other info at any time.
Old Aug 22, 2005 | 11:55 AM
tilt's Avatar
yep. used p28 basemap here too.
DOHC Kid
May 27, 2008 04:47 PM
thewrai6th
Oct 18, 2007 11:29 PM
BLUE EH3
23
Jan 18, 2007 11:07 AM
finest_GSR
Oct 6, 2006 05:07 PM
honda89ef
23
Mar 14, 2005 06:12 PM
