Running Hot/over heating
Old Aug 23, 2005 | 09:10 PM
kyle h.'s Avatar
Default Running Hot/over heating
The car does not over heat. It runs up to about 230* on the highway 90* outside temps
Idling the after market 12" slim fan turns on at 207* (stock?) As long as temps dont reach 220*, the fan can cool the car down to 205*
Removed 3.5" thick fmic, temp wouldn't budge over 180*
Replaced fmic, no bumper cover/skin, temps got to 200*
New water pump, termostat.
The radiator has been replaced by the previous owner, same as the cap, they look "ok". Not sure how old they are. Car has 163k miles on it.
Good fluid, no air pockets.
The temps will come back down to 217* after getting off the highway, but has trouble getting them down any more than that.
Its a z6 turbo with half rad in a del sol si, no a/c.
Think I should get a new radiator from parts store? $80 for OEM type from Advance Auto
Any other suggestions/ideas/options? Thanks for any help!
Old Aug 23, 2005 | 09:15 PM
kyle h.'s Avatar
Default Re: Running Hot/over heating (kyle h.)
P.S. I don't want an aftermarket performance radiator. I don't think this will solve the problem, from previous experience.
Flow is key. both coolant and air.
Old Aug 24, 2005 | 05:19 AM
FAUCON's Avatar
https://honda-tech.com/zerothread?id=1310483&page=1
Old Aug 24, 2005 | 06:03 AM
kyle h.'s Avatar
Default Re: (FAUCON)
Thanks for that reply. I saw that stock cars without A/C have "block-off" plates. I'm going to give that a try. Unless I can mount a full sized rad in a del sol?
Old Aug 24, 2005 | 12:00 PM
BodyKits NW's Avatar
Default Re: (kyle h.)
You just answered your own question. It's a air flow issue, and the FMIC is the cause. This airflow problem is common on a lot of honda-tech members cars.
Old Aug 24, 2005 | 12:05 PM
nonvtecD's Avatar
Yep, FMIC is killing the flow, happened to me and now I have to ride around with my heat on in hot weather. This seems like this has been a really popular topic this summer, I wonder why. Everyone must be buying front mounts.
Old Aug 24, 2005 | 12:16 PM
Boognish's Avatar
Default Re: (nonvtecD)
I have the same problem. https://honda-tech.com/zerothread?id=1349961
230? wow. Where does the needle sit on the stock temp gauge? Below half, half or higher?
Old Aug 25, 2005 | 06:38 PM
kyle h.'s Avatar
Default Re: (Boognish)
I blocked off the spot where the a/c used to go and it's only gotten to 210*
I just made a sheet metal duct/block-off and I managed to fry the ECU..
I might add some more ducts around the sides of the intercooler.
Old Aug 25, 2005 | 08:43 PM
red_crx's Avatar
happens to me too, it that your Radiator isn't getting enough air.
Old Aug 26, 2005 | 06:59 AM
Turbocivic94's Avatar
Default Re: (red_crx)
I have the same problem, its you large intercooler. I have precision aic-750 and it blocks the whole front. This happens only on hot days so I dont drive my car on hot days. I'l drive it in the evening cause its cooler.
Old Aug 26, 2005 | 07:22 AM
vaporboy12's Avatar
Default Re: (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">P.S. I don't want an aftermarket performance radiator. I don't think this will solve the problem, from previous experience.
Flow is key. both coolant and air.</TD></TR></TABLE>
i think where you live it will solve your problem. i habe a greddy type 24 which is huge.my under hood temps are insane. but my coolant temp never go above the half way mark on the cluster.
have you tryed to jump you fan so its on all the time in the key is on?
adpnsmp
16
Feb 25, 2013 12:39 PM
DelSolMarine
May 22, 2008 02:50 PM
JDMTYPER
52
Sep 20, 2004 08:28 AM
bigslimdog
Aug 10, 2004 03:37 PM
FOrSfEd
Feb 5, 2004 04:48 PM
