uberdata 1.66, 1.7 problems...
Old Aug 19, 2005 | 10:31 PM
kasso's Avatar
Default uberdata 1.66, 1.7 problems...
can someone please email me uberdata 1.66? i've searched the pgmfi.org forums, and the ud forum. nothing. kasso@nyc.rr.com
btw, i dont want 1.7 because i tried making a basemap with it, imported the bin from off the chip to see whats been written, and opened the file with ud. it said that it had an error opening L1H1_AF.asm file and that it would cause ecu failure. and it cant be the way the chip is burning because i did the same thing with crome and no errors.
Old Aug 20, 2005 | 02:02 AM
BlackCRX's Avatar
was the file you opened/saved in the same folder as uberdata ??
if not then theres your problem
Old Aug 20, 2005 | 02:58 AM
non-VTEC's Avatar
Default Re: uberdata 1.66, 1.7 problems... (kasso)
you need to save and open all your bin's in the same folder that you have uberdata saved in or you will get that message.
use 1.70 it's the most stable version
Old Aug 20, 2005 | 02:03 PM
mchuang's Avatar
why dont you try crome very user friendly and works without problems..
Old Aug 20, 2005 | 02:57 PM
King Tut33's Avatar
Default Re: (mchuang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">why dont you try crome very user friendly and works without problems..</TD></TR></TABLE>
Yeah Crome has no problems. . Anyways I suggest you place the .bin file in the Uberdata folder and continue using the most stable officially released version 1.7 found here:
http://uberdata.pgmfi.org/foru...=2001
If you HAVE to use 1.66, here are some options:
http://www.pgmfi.org/twiki/bin...Tools
By the way 1.66 and 1.7 .bins are not compatible so if you don't know what version your chip was made in then good luck.
Old Aug 20, 2005 | 03:00 PM
nota-eg's Avatar
Default Re: (King Tut33)
I loved the crome stock P28 map. I think it's better than the one that comes stock in the ECU (TO ME, SIMPLY MY OPINION! )
You could save the crome P28.bin in the uber file and open that, and then do your basemap from there.
Old Aug 20, 2005 | 04:13 PM
mchuang's Avatar
i dont think you can open a crome map with uberdata...could be wrong
Old Aug 20, 2005 | 04:52 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchuang &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you can open a crome map with uberdata...could be wrong</TD></TR></TABLE>
I don't know, I opened the GSR.bin, and then went to Import P28, opened the crome P28.bin and had it opened in both Uber and Crome.
The fuel maps were almost identical, except uber rounded instead of doing the .05 or .005 that was in the crome map.
Old Aug 21, 2005 | 12:22 PM
kasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">
By the way 1.66 and 1.7 .bins are not compatible so if you don't know what version your chip was made in then good luck. </TD></TR></TABLE>
What do you mean? can't i just completely erase the chip and re-burn it?
btw, the chip isnt installed yet, but it has a crome p30 map on it for ls/vtec.
Old Aug 21, 2005 | 12:35 PM
SOHCEK-Turbo's Avatar
Default Re: (kasso)
I went with Crome for the same reason you are having problems. I have not yet had any problems with crome at all since installed and tuned. For some reason I couldnt open any p28 maps or p30 maps on Uber which was my first choice but went Crome and havent had any problems. Yes they both have their problems small bugs, but I just seem to read more problems coming from Uber users then Crome. I do like the free datalog on Uber, to bad I havent been able to use it. If Crome Pro was free with autotune, Im sure that would be the first choice for everyone. Yup and yes they both open the p28 and p30 basemaps. You can also open Uber boost maps with Crome as well.
Old Aug 21, 2005 | 12:44 PM
nota-eg's Avatar
Default Re: (EK-TSOHCV-TaKRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TSOHCV-TaKRider &raquo;</TD></TR><TR><TD CLASS="quote">I went with Crome for the same reason you are having problems. I have not yet had any problems with crome at all since installed and tuned. For some reason I couldnt open any p28 maps or p30 maps on Uber which was my first choice but went Crome and havent had any problems. Yes they both have their problems small bugs, but I just seem to read more problems coming from Uber users then Crome. I do like the free datalog on Uber, to bad I havent been able to use it. If Crome Pro was free with autotune, Im sure that would be the first choice for everyone. Yup and yes they both open the p28 and p30 basemaps. You can also open Uber boost maps with Crome as well.</TD></TR></TABLE>
I think I'm going to re-dl crome and play with that some. I just like the layout of Uber better. The Blue to purple to red is nice. Crome has funky colors IMO.
How does crome work with 310 peak/hold injectors? Uber is being a peta-munching peckerhead.
How much is Crome Pro?
Old Aug 21, 2005 | 01:01 PM
Default Re: (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">
How much is Crome Pro?</TD></TR></TABLE>
Dont really care to much about the colors of the program but i just know that Crome has wroked for me, while I couldnt even get Uber to open. And I can say that I am a very software oriented person. Im using DSM 450s w/out a problem havent tested 310s before but I figure any injector size will work. Crome Pro is $150.
Old Aug 21, 2005 | 04:46 PM
King Tut33's Avatar
Sounds to me like the problem with alot of Uberdata users is simply user error. If you want to use Uberdata don't start with some other random map. You gotta make your own and go from there. If you don't want to make your own then stick with Crome. To me Uberdata is simple. Open up StockGSR and import which ever fuel and ignition maps you need which are supplied with Uberdata and then start tweaking. You can't just open up some random .bin file and go from there. As far as 1.66 and 1.7 they use different fuel setups so the fuel maps don't transfer over properly between versions.
Old Aug 21, 2005 | 07:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds to me like the problem with alot of Uberdata users is simply user error. If you want to use Uberdata don't start with some other random map. You gotta make your own and go from there. If you don't want to make your own then stick with Crome. To me Uberdata is simple. Open up StockGSR and import which ever fuel and ignition maps you need which are supplied with Uberdata and then start tweaking. You can't just open up some random .bin file and go from there. As far as 1.66 and 1.7 they use different fuel setups so the fuel maps don't transfer over properly between versions.</TD></TR></TABLE>
Damn you are right. I just tried it and it worked. I have 1.8. I opened up the GSR bin and imported the p28 maps over and created a boost basemap. 1.8 comes with the step retard option. Im going to mess with Uber now and see what I can do with it. going to tune next weekend.
.Grimace
Nov 30, 2006 12:59 PM
Ragecloak
11
Jan 24, 2005 12:30 PM
streetbreed
Nov 20, 2003 07:14 AM
wildstallion
Oct 12, 2003 06:44 AM
Mr. Softee
Jun 21, 2003 07:35 PM
