Not boosting (help)
Old Aug 21, 2005 | 10:18 AM
1FastCoupe's Avatar
Default Not boosting (help)
Sorry if this thread is a repeat but the search server is down..we put a turbo kit on a gsr last night and everything is hooked up right and all the vaccum lines are right. all the charge pipes are good but we took the car out and the car wont go into boost. could the 5 bolt flange be a cause of no boost if its the wrong kind..thats the only thing we didnt check..please let me know if you have had a similar instance..
Old Aug 21, 2005 | 10:19 AM
N20civicB18's Avatar
Default Re: Not boosting (1FastCoupe)
check for leaks in your charge pipes and make sure your wastegate is closed.
Old Aug 21, 2005 | 10:45 AM
1FastCoupe's Avatar
we did that and even pulled off a vaccum line to see if it would go into boost but still nothing..its a new tial wastegate as well..
Old Aug 21, 2005 | 12:06 PM
98_4drCivic's Avatar
wastegate...
Old Aug 21, 2005 | 03:35 PM
1FastCoupe's Avatar
how can i test the wastegate?
Old Aug 21, 2005 | 03:44 PM
victoriasamantha's Avatar
Default Re: (1FastCoupe)
what is the car doing, is it running ok besides that
Old Aug 21, 2005 | 04:29 PM
1FastCoupe's Avatar
car is running i hear the turbo spool..if i rev it up i can feel air come out the bov when the throttle plate closes but when i drive it it wont go into boost..
Old Aug 22, 2005 | 01:33 AM
Maxime's Avatar
Maybe you're boost gauge isnt installed properly.
Old Aug 22, 2005 | 02:45 AM
TurboEH2's Avatar
Default Re: (Maxime)
When i first installed my tial wastegate i forgot to put this little thing in the bottom, and i wouldnt build any boost either. might wanna check that.
Old Aug 22, 2005 | 06:17 AM
1FastCoupe's Avatar
the boost guage is right it reads the correct vaccum and goes to 0 when we floor it but no boost..
"When i first installed my tial wastegate i forgot to put this little thing in the bottom, and i wouldnt build any boost either. might wanna check that".
The fire ring is in the bottom of the wastegate.
Anyone else had a problem not building boost after turbo install..?
Old Aug 22, 2005 | 06:49 AM
wantboost's Avatar
Who is Mr Robot?
check all of the intercooler piping conenctions. you have a boost leak... a big one
Old Aug 22, 2005 | 08:35 AM
TEG777's Avatar
Default Re: (wantboost)
i have the same problem, when my car is ideling and i rev it up it wont go past the vaccume side on the boost gauge, i checked for leakes, couldnt find one
Old Aug 22, 2005 | 09:35 AM
wpgcivic's Avatar
for me anyways it was a charge pipe that came loose
Old Aug 22, 2005 | 06:18 PM
scartail's Avatar
you can try to pressurize the charge pipes with a compressor or air pump (engine off). and use soapy water to trace it down.
Old Aug 24, 2005 | 07:45 AM
terd50's Avatar
Default Re: Not boosting (scartail)
I had a smiliar problem so I redid my whole charge piping setup and I found out the boots had some cracks in them, and also my boost gauge line had a kink in it.(make sure it is tapped somewhere on the intake manifold) The wastegate may be a problem with the psi it is set at as well.
Old Aug 24, 2005 | 12:43 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (TEG777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEG777 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem, when my car is ideling and i rev it up it wont go past the vaccume side on the boost gauge, i checked for leakes, couldnt find one</TD></TR></TABLE>
the car wont build boost when there is no load on the motor. go drive it around and it will build boost
Old Aug 24, 2005 | 02:03 PM
LSBOI's Avatar
i had this same problem when i went to get tuned. check you downpipe, and make sure it is on tight enough. like previously stated you have a boost leak.
richboi
Apr 15, 2007 07:46 PM
japspec
Oct 24, 2003 07:49 PM
blackfrohatch
Aug 26, 2003 06:47 AM
Fired Honda
Jul 18, 2003 05:42 AM
blu_si
Oct 1, 2002 04:20 PM
