How much zex to use on a b16
Old Aug 22, 2005 | 01:57 PM
ek_slut's Avatar
Default How much zex to use on a b16
I have a b16 in my 91 std hatch. Its all stock other than i/h/e. I dont have any fuel managment mods. Im getting a zex 4 wire dry kit with the brainbox. I was wondering how much I should run. I was thinking around a 50 shot. Anyone have any past experience on a b16?
Old Aug 22, 2005 | 02:03 PM
N20civicB18's Avatar
Default Re: How much zex to use on a b16 (c_sweet06)
50 shot of nitrous you should be fine
Old Aug 22, 2005 | 02:35 PM
OMG B16's Avatar
I had the same kit on my b16, ran a 50shot for a while, upped it to a 75 BOOM
Old Aug 22, 2005 | 02:51 PM
Default Re: (Sick00SiCoupe)
yea if your going to run more then a 50shot i would highly reccomend a wet kit... even with a 50shot your much better off with a wet kit.
Old Aug 23, 2005 | 02:19 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick00SiCoupe &raquo;</TD></TR><TR><TD CLASS="quote">I had the same kit on my b16, ran a 50shot for a while, upped it to a 75 BOOM</TD></TR></TABLE>
How'd you pull that one off? I ran a 75 shot Zex on my D16 for almost 2 years with no problems at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">yea if your going to run more then a 50shot i would highly reccomend a wet kit... even with a 50shot your much better off with a wet kit.
Nonsense. Dry kits are fine if you have the right fuel management.
Old Aug 23, 2005 | 02:27 PM
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Nonsense. Dry kits are fine if you have the right fuel management.</TD></TR></TABLE>
true but I doubt hes going to have his ecu chipped and tuned on nitrous just so he can use it every so often
Old Aug 23, 2005 | 02:36 PM
RyanEJ8's Avatar
Default Re: (N20civicB18)
true but I doubt hes going to have his ecu chipped and tuned on nitrous just so he can use it every so often</TD></TR></TABLE>
For just a 75 shot of ZEX the only thing required is a 255lph high pressure fuel pump. An adjustable fpr is recommended.
Old Aug 24, 2005 | 12:47 AM
f1 vtec's Avatar
From expereince with stock fueling & a b16 combined with a zex dry kit i would pull back the timing a little and stick with a 50 shot max.
Weve ran a 75 shot regularly with a vafc and 255lph without any trouble at all
Old Aug 24, 2005 | 01:35 AM
SiKid86's Avatar
Default Re: (f1 vtec)
I ran the 70 for a bottle and decided I needed boost the nitrous didn't last long enough
Old Aug 24, 2005 | 07:05 AM
tuoniz's Avatar
Ran a 50 shot fine no problems for a long time
Eric724
Jun 10, 2011 04:39 AM
bam_89
10
Jul 30, 2008 12:54 AM
spuddo01
Jul 13, 2006 09:13 AM
4ghatch
Jul 14, 2004 07:59 PM
Rob!
20
May 13, 2003 03:27 PM
