turbo crx question
Old Aug 22, 2005 | 06:20 PM
serialkiller's Avatar
Default turbo crx question
My 91 crx si is currently running a mini-me set up... i would like to add a turbo kit that has minimal to none custom fabrication (straight up bolt-on kit). Does anybody know a kit that will bolt up without any problems or customization? Problems include, clearing ac, clearing radiator, clearing x-memeber.. etc etc etc.. Thanks in advance to all that can help.
Jorge
Old Aug 23, 2005 | 04:31 AM
Default Re: turbo crx question (serialkiller)
anybody?
Old Aug 23, 2005 | 08:13 AM
DaveF's Avatar
a rev hard kit would work out without having to cut alot or relocate the radiator.
another way to go is Spoolin Performance, Phil's log mani should also clear everything with no problems, its also stainless so it will "bling" a bit more than the rev hard or any cast steel manifold.
Old Aug 23, 2005 | 06:17 PM
Default Re: turbo crx question (Dturbocivic)
are you sure about the rev hard?
http://www.turbo-kits.com/crx_turbo_kits.html
according to this turbo kit dealer.... the rev hard is not direct bolt-on and does require removing ac.
Old Aug 24, 2005 | 02:29 PM
i feel so cold...
Old Aug 24, 2005 | 04:34 PM
anybody? I got some info on an edelbrock kit... but its still labeled for a 92-95 civic ex so not sure if its compatible all the way on my car...
Old Aug 28, 2005 | 04:26 PM
anybody?
Old Aug 28, 2005 | 06:31 PM
b18-c-rx's Avatar
If you're going turbo in a crx, you probably should ready yourself to let go of AC, because that is a huge obstacle. I've never done a d-series turbo crx, but I'm pretty sure you are going to have to make some bumper/frame modifications even if you found a kit that was aligned and optimized for your setup.
Old Aug 28, 2005 | 07:55 PM
Default Re: turbo crx question (b18-c-rx)
even with the 92-95 civic ex greddy kit?
Old Aug 29, 2005 | 08:48 AM
b18-c-rx's Avatar
I'm not sure, but I would definitely not be surprised. Maybe someoen else that has that kit or has seen it can chime in.
CRXherbie91
May 27, 2008 05:58 AM
CRXherbie91
May 25, 2008 05:03 PM
Integra_drk
Apr 10, 2006 04:27 PM
03 Civic Si
Jun 27, 2004 09:00 PM
Snafu-Si
Jan 31, 2002 11:36 PM
