AFC pressure sensor setting
Old Aug 23, 2005 | 02:10 AM
Fallen86's Avatar
Default AFC pressure sensor setting
Hey guys i'm running a an safc on a 97 civic (obd2) now the only pressure sensor setting that remotely works for me is <U>5 in 5 out</U>. the manual says it should be 6in 6out. but when i put em on 6 the engine stalls. but when on 5. it doesnt seem to be able to read pressure right. my boost guage says 6psi but the afc still says negative pressure. anyone got any other sensor setting they are at that works fine? there are a lot of combinations... Thanks
Old Aug 23, 2005 | 05:59 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: AFC pressure sensor setting (Fallen86)
Like the manual says, it should be 6 in 6 out. But if that don't work, go with what works
Old Aug 23, 2005 | 01:24 PM
Fallen86's Avatar
Default Re: AFC pressure sensor setting (Vt4cPwn35)
thanks. for the reply. it seems that 6 nd 6 Will work but u gotta up the throttle with the throttle screw a bit. but 5 and 5 still makes my car idle a little higher... next problem, boost leak!
ZCHondaCRX91
Engine Management and Tuning
Dec 29, 2011 01:48 PM
redline7
Jan 2, 2008 08:32 PM
civel
Jan 22, 2006 12:00 PM
The Weather Man
Aug 13, 2005 10:45 AM
pissedoffsol
Oct 20, 2003 08:14 PM
