need a good piston & rod combo on stock sleevs B16A2 for 20PSI
Old 08-21-2005, 01:15 AM
RACEPAK's Avatar
Default need a good piston & rod combo on stock sleevs B16A2 for 20PSI
hello everybody.
got a b16a2 that's waiting for a rebuild for boost.
i need you guys to recommend me a good piston & rod setup for reliable power.
i was thinking about tuner toys rods and wisco or je pistons and arp studs ?!?
what about head gasket should i go oem or other brand?
also which piston rings do you guys recommend?
best regards moshik galimidi
Old 08-21-2005, 01:21 AM
T4eg's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (RACEPAK)
eagle rods CP pistons
Old 08-21-2005, 06:53 AM
Makdaddynuge's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (T4eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods CP pistons </TD></TR></TABLE>
Old 08-21-2005, 06:54 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (Makdaddynuge)
manley rods, cp pistons, oem headgasket, darton mid or golden eagle hd sleeves, arp or goldeneagle head studs
Old 08-21-2005, 07:28 AM
BlueShadow's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (wantboost)
-Pauter or Manley rods
-CP pistons
-Cometic MLS HG or OEM if you stick with stock bore size
-ARP head studs
-ARP rod and main bolts
Old 08-21-2005, 07:47 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (BlueShadow)
manley and pauter rods come with arp2000 rod bolts. and the stock mani blts are more than enough. all the mani studs do is cause you to have to linebore your block which is about 220 bucks
Old 08-21-2005, 08:56 AM
mrbsponge's Avatar
i am using JE pistons and a set of crower rods, have gone over 20 daily and havent had a problem in 2 years
Old 08-21-2005, 09:09 AM
dome's Avatar
Default Re: (mrbsponge)
i like wiseco and crower. wiseco comes with coated side skirts.
hoo my gosh
03-28-2008 08:50 AM
spunautosports
11-08-2006 07:37 PM
egvtec
12-12-2005 03:49 PM
andrewasf77
14
06-04-2004 08:43 AM
Quick Reply: need a good piston & rod combo on stock sleevs B16A2 for 20PSI
