Endyn Breather and Turbo Specs
BCICAN
Has anyone installed an Endyn Breather kit on an LS/VTEC...is it possible? Have pictures?
Also, do you know the torque specs for the bolts that on the turbo housing...both on the exhaust and on the compressor? I am talking about the bolts that hold the plates to prevent the turbo from just spinning around. Thanks.
BCICAN
Re: Endyn Breather and Turbo Specs (B20TDC2)
thats what I thought....because the B18B block has the pcv valve (the little black box by the oil filter) correct?
Modified by Dunc at 10:53 AM 8/20/2005
