Wastegate gasket question
Old Aug 23, 2005 | 12:23 PM
GWInquisitor14's Avatar
Default Wastegate gasket question
I have a tial 38mm wastegate and the neukin manifold. Recently, the tial bolts that hold the wastegate onto the manifold keep creeping out, causing a major exhaust leak before the turbo and the gasket to burn up. I am using the gasket that comes with wastegate, its like a paper gasket with a metal screen in the middle. Will permatex RTV ultra copper gasket maker work on this setup instead of the other one. The gasket I was supplied with seems to be too weak but I am not sure if the RTV will be any stronger. Also, to keep the bolts in should i just use some red loctite and good amount of torque?
Old Aug 23, 2005 | 12:52 PM
B16Civic93's Avatar
Default Re: Wastegate gasket question (GWInquisitor14)
sounds good to me,
Old Aug 23, 2005 | 01:05 PM
angela_itr's Avatar
Try a metal gasket from an exhaust shop, I used one with 2 layers that compress, solved my wastegate blowing problems. Those paper gaskets are no good.
Old Aug 23, 2005 | 01:08 PM
dc2legend's Avatar
Default Re: Wastegate gasket question (angela_itr)
The gaskets that come with the Tial gates are garbage, mine went out in like 2 days. Try a copper one. Either make or buy.
Old Aug 23, 2005 | 01:49 PM
kameleon23's Avatar
Default Re: Wastegate gasket question (dc2legend)
dont use a gasket at all
Old Aug 23, 2005 | 01:56 PM
vaporboy12's Avatar
Default Re: Wastegate gasket question (kameleon23)
pick up more power without a gasket
Old Aug 24, 2005 | 01:41 PM
Default Re: Wastegate gasket question (vaporboy12)
ya ive got the RTV gasket on there right now, im probably taking the car to the track today so i will see how she holds up. How much would it cost to get one made?
Old Aug 24, 2005 | 07:22 PM
vaporboy12's Avatar
just dont run a gasket. it metal to metal dont need a gasket same thing as your downpipe
Old Aug 24, 2005 | 10:57 PM
well ive got the silicone on there and its holding up really well. I ran some decent times tonite. I thought there wasnt enough on there, but its good now. If i have a problem in the future, ill probably say screw the gasket.
Old Aug 25, 2005 | 03:20 AM
AzntaggeR's Avatar
TSPeed Factory
i'd just run without a gasket.
Old Aug 25, 2005 | 12:11 PM
TurboCoop's Avatar
Default Re: Wastegate gasket question (AzntaggeR)
no gasket
Old Sep 25, 2005 | 09:49 AM
376R's Avatar
Default Re: Wastegate gasket question (TurboCoop)
No gasket? i was wondering why when i swapped wastegates the original tial wasnt running a gasket.. but there was obvious leaking, the head was black and the wg was discolored.
So when i put the new one on i used the gasket, well i blew them out yesterday, car sounds lousy and is slower. I hear dont use a gasket at all... but wont i have the same problem as before with leaking? how do you prevent any kind of leak? i hear a thin layer of silicone. i wanted to ask opinions before i do so. thanks
Old Sep 25, 2005 | 11:30 AM
2point2's Avatar
ultra copper is good stuff.. i'm not sure how well it works with heat from turbos though..
Akalima
Aug 25, 2005 11:07 AM
Vinhtran17
May 12, 2004 02:21 PM
HondaCutter
Sep 9, 2002 01:11 PM
Etylorcen
Feb 24, 2002 01:39 PM
