Need help socketing obd0 ecu for hondata, walkthrough if any?
the title basically says it all but, i got a oldschool stage 3B hondata bluebox, and I need to figure out how to socket my ecu, i got the chips and hookups but cant find a link on hondata.com to do it, if you can send me a link or the knowladge id appreciate it.
Re: Need help socketing obd0 ecu for hondata, walkthrough if any? (R6E6I6D)
http://www.pgmfi.org/twiki/bin...pping
There's a decent link to help you out.
Basically you want to desolder the 28 pin socket and the spot labeled CN3 in a PR3/PW0
Re: Need help socketing obd0 ecu for hondata, walkthrough if any? (xenocron)
desolder than solder what?? will i need desoledring braid i havent taken the ecu apart yet,?
Desolder (or remove the stock chip) the 28 pin spot and then solder back in a socket. Place the 4 pin header for Hondata in the spot labeled CN3.
And read the link...it goes over it all.
hey thanks a lot man, i really appreciate it you helped me out big time
is there a way you canhelp me on hooking up launch control to clutch safty switch><<
http://www.xenocron.com/bins
i know there is one BRE tuned B16 map up there by J. Davis
As far as a launch control to a clutch safety switch...thats not a feature of BRE as far as i know....LC is built in but anything for a clutch switch
i can make u a bin...and launch controll doesnt need a switch....you can set it up off mph
projectef
07-25-2006 03:22 AM
