which oil cooler is everyone using?
Old Aug 21, 2005 | 06:40 AM
non-VTEC's Avatar
Default which oil cooler is everyone using?
hey guys.
the search function has been down for a while so i cant find any info on what seems to be the most popular engine oil cooler.
i have my eye on the B&M oil cooler which is not to expensive but will it work good for a boosted honda engine. the cooler itself looks kinda small so will it be very effective?
http://www.bmracing.com/index....id=79
then there is also FAL (flex-a-lite) which has 2 types of coolers. one is their "standard" duty with a cooler core about the same size as the B&M and they have a heavy duty core which is about double the thickness (but almost double the price)
http://www.flex-a-lite.com/aut....html
i don't want to spend a huge amount of money on an oil cooler if it's not going to make a huge improvement so will the smaller of the two oil coolers be good enough to control a little of the heat?
what is everyone else using?
Old Aug 21, 2005 | 07:16 AM
TurboCoop's Avatar
Default Re: which oil cooler is everyone using? (non-VTEC)
I just bought a universal oil cooler from summit for $30, and a sandwich adapter to run the lines, but I the sandwich adapter leaked like a bitch so I took it off. I also didnt want to wear out my oil pump so I dont think I am going to reinstall it until I upgrade to a vtec oil pump.
Old Aug 21, 2005 | 09:10 AM
non-VTEC's Avatar
Default Re: which oil cooler is everyone using? (TurboCoop)
i was thinking of making my own custom oil cooler setup as well....it might come out cheaper.....but i want some thing that works efficiently.
which sandwich adaptor do you buy that leaked?
Old Aug 21, 2005 | 10:20 AM
nfn15037's Avatar
Mocal
Most of the sandwich adaptors I have seen use 3/8 NPT, which is too small for our motors IMO. Either get the Mocal plate with 1/2 NPT or go with a full setup with an oil filter reloaction kit. Whatever you do, make sure your setup includes a thermostat.
Edit: I also would NOT use anything that utilizes hose clamps etc. At least use Aeroquip socketless hose.
Old Aug 21, 2005 | 10:42 AM
drift2004's Avatar
Default Re: which oil cooler is everyone using? (nfn15037)
i got a b&m oil cooler from summit for 50 bucks 11x7 its nice
Old Aug 21, 2005 | 03:54 PM
vtec94civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Mocal
Edit: I also would NOT use anything that utilizes hose clamps etc. At least use Aeroquip socketless hose.</TD></TR></TABLE>
Matt i really need my car to get tuned. Let me know whatsup. My # is 617-593-3736. Get back to me soon i really need this done asap.
Old Aug 21, 2005 | 06:33 PM
TurboCoop's Avatar
Default Re: which oil cooler is everyone using? (vtec94civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking of making my own custom oil cooler setup as well....it might come out cheaper.....but i want some thing that works efficiently.
which sandwich adaptor do you buy that leaked?</TD></TR></TABLE>
It was some $40 ebay one, with a built in thermostat, I dont know if I installed it wrong or what, but it poured out oil when I started it up. I also didnt feel to good about using the hose clamps either, next time I do an oil cooler i'm goin with the socketless fittings or something that i know wont blow off or leak.
cioli
Jul 13, 2005 07:22 AM
hardboiled egz
Nov 20, 2002 02:55 PM
SoulSurfer
Nov 8, 2002 06:22 AM
TurBoXBirD16
Jul 9, 2002 09:45 AM
94DelSolVTEC
Feb 1, 2002 06:31 PM
