Overheating
Old Aug 22, 2005 | 10:47 PM
Lucky_Smurf's Avatar
Default Overheating
Ok here's what I've done so far. Replaced the thurmostat and rigged the fan to come on with the key. The switch is broken. I've just put in all new coolant and everything as well but she still get's damn hot. She'll heat up then cool off a bit and then heat up and cool off weather I'm in boost or not. I also checked the dipstick oil for head gasket problem and it seems clean as a whistle. I'll drain tomorrow to make sure. I'm thinking the only things left to do are to upgrade to a bigger fan and better radiator. I'm still running a stock 00 SI radiator and a pretty small slim fan, cheap deal, but now i'm running a 2.0 gsr.
Any other ideas?
Anyone know a good place for a custom radiator? Good slim fans to get that pull lots of CFM?
Old Aug 23, 2005 | 08:03 AM
Default Re: Overheating (Lucky_Smurf)
anyone?
Old Aug 23, 2005 | 08:29 AM
ebp_dc2's Avatar
put in a mugen thermostat, or something about as cold as that...and run more water than coolant...thats what i did, cleared up my problem now my temps never go above 190
Old Aug 23, 2005 | 08:30 AM
DaveF's Avatar
it sounds to me as if you have an air pocket in your coolant system someplace.
if you are looking for a custom radiator with fan i recomend going to C&R. speak with Kevin. V
Old Aug 23, 2005 | 09:46 AM
Default Re: Overheating (Dturbocivic)
Yeah I need to check for air pockets tonight. Does C&R have a website?
jeremyrocksursox
Oct 20, 2009 05:54 AM
vlude99
Jul 30, 2009 05:58 PM
turbodailydan
Jul 19, 2009 06:10 PM
JDMTYPER
52
Sep 20, 2004 08:28 AM
mika
Aug 8, 2004 05:00 PM
