Identify this turbo...
Old Aug 24, 2005 | 10:48 AM
SL0WEGG's Avatar
Default Identify this turbo...
I have this turbonetics turbo, problem is i dont know what trim it is or anything. The guy i bought it from says its a t3/t4. but im not too sure. i know the exhaust is a .63 but i dont know what stage wheel it is. looked on turbonetics webpage and didnt find anything. well they did list specs but i couldnt find the last two numbers that they list to figure out what stage it is. emailed turbonetics with no response. there is also a v imprinted on the compressor housing to the right of where the nipple is. on to the pics
heres whats imprinted inside the exhaust
exhaust wheel is 2 1/4" in diameter
compressor inlet is 2 1/2" wide and outlet is 1 3/4"
imprint on compressor housing
reference to size i guess
TIA
Old Aug 24, 2005 | 10:52 AM
STHPERFORMANCE's Avatar
Without Measuring the wheels and such u arent gonna really know what spec it is visually cause most turbos all look alike.
I see however it does has a casting number by turbonetics. U can prolly give them a call and see if they can provide any info for you.
Last resort, Pop off the compressor cover and measure the wheel.
Good Luck
Old Aug 24, 2005 | 10:55 AM
SL0WEGG's Avatar
Default Re: (STHPERFORMANCE)
what type of tool am i supposed to use to measure the wheel?
Old Aug 24, 2005 | 11:06 AM
dial caliper
Old Aug 24, 2005 | 11:26 AM
veggiemaster's Avatar
looks like my turbonetics t3/t4
edit: im retarded. you've already established that. ill try and get my specs..
Old Aug 24, 2005 | 11:38 AM
SL0WEGG's Avatar
Default Re: (veggiemaster)
i somewhat measured it with a ruler. i know i know its not as accurate is the dial caliper but it was 2.25 inches. and from what i believe the trim is measured in millimeters. and searching online i found some calulaters i guess on converting inches to mm. and i found that 2.25 inches is 57.15 mm. so im going to assume it is a 57 trim. but till i go buy the dial caliper which will probably be tomorrow. i will confirm. if someone thinks otherwise please let me know
Old Aug 24, 2005 | 11:56 AM
SL0WEGG's Avatar
Default Re: (boostedej1)
now after looking deeper into turbonetics.com. i found that they have a list of specs. and after looking at this chart. i found that there was i guess a v trim or whatever. i dont know . and it says the inducer is 2.180" which could be what it is. but i dont know hahaha. i will just have to confirm this for myself tomorrow on my day off. how do you figure out what stage the exhaust wheel is. there is a series of numbers on the side which are 20358 which means its a .63ar but there is supposed to be 2 numbers after that. help me out. i mean its not that important. but id just like to know
this is the chart
Old Aug 24, 2005 | 12:42 PM
AspectIndustries's Avatar
Default Re: Identify this turbo... (boostedej1)
Looks like a Stage3 I beleive. Something like a 57 trim.
Ask Ben, at import-parts.com. (hes here on HT also)
He knows turbonetics really well. But im sure its a 57/63
Old Aug 24, 2005 | 12:48 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Identify this turbo... (synik)
t3/t04b.
v trim
starge 3 exhaust wheel
Old Aug 24, 2005 | 01:20 PM
cubish's Avatar
Default Re: Identify this turbo... (wantboost)
its a turbonetics 60-1 , stage 3 back wheel. the normal t3/t4's only have 6 blades on the front compressor wheel. ive had plenty of them
Old Aug 24, 2005 | 01:27 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Identify this turbo... (cubish)
all t04b are in effect 60-1 wheels, hence the 7 blade design
Old Aug 24, 2005 | 07:28 PM
SL0WEGG's Avatar
awesome, thanks guys. . one more question. how did you figure out it was a stage 3 exhaust wheel?
Old Aug 25, 2005 | 11:19 AM
SL0WEGG's Avatar
okay so i measured it with a dial caliper. but i dont know if i measured correctly. from what i measured it was 57mm might be a little less because i didnt know where to measure
Old Aug 25, 2005 | 05:31 PM
SL0WEGG's Avatar
i need to know for sure
Old Aug 25, 2005 | 05:41 PM
project dc2's Avatar
measure the outside .. which you did .. 57MM
measure the LARGE back portion where the blade flares out .. get a measurement
and devide them and you get the trim.
however you already researched it was a V trim ?
its a TO4B wheel thats for sure.
Old Aug 25, 2005 | 05:49 PM
SL0WEGG's Avatar
Default Re: Identify this turbo... (project dc2)
yeah i dunno. hahaha. it has a small v imprinted on the compressor housing with led me to believe it was a v trim. but what size is a vtrim. 50,55, or 57. this **** confuses me. i wish they would just put numbers on it
Old Aug 25, 2005 | 05:53 PM
wll measure it . and devide it and youll get a trim number if u want.
or you can use that chart you had to reference to see what it is under turbonetics lingo
Old Aug 25, 2005 | 09:56 PM
SL0WEGG's Avatar
im too lazy . thanks for all the help. this may be too big for a mini-me. but it was cheap what can i say
Old Jan 4, 2006 | 12:20 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Bringing this back from the dead to confirm...
If there are six compressor wheel blades, then it's a T04e housing?
And if there are seven compressor wheel blades, then it's a T04b housing?
Old Jan 4, 2006 | 01:34 PM
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">t3/t04b.
v trim
starge 3 exhaust wheel</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">all t04b are in effect 60-1 wheels, hence the 7 blade design</TD></TR></TABLE>
BlakeJ53
Mar 8, 2009 02:28 PM
AJxr
Nov 15, 2008 12:12 PM
DC2tuner
Aug 3, 2005 06:57 AM
Sunlight
Apr 6, 2005 10:04 AM
sparkz
May 15, 2003 04:36 PM
