3 bar map
Old Aug 21, 2005 | 02:27 PM
victoriasamantha's Avatar
Default 3 bar map
can anybody send me pics of 3 bar gm map sensor install and where do buy the plug for it
thanks
Old Aug 21, 2005 | 02:41 PM
LVB18Civic's Avatar
Default Re: 3 bar map (victoriasamantha)
https://honda-tech.com/zerothread?id=602480
Old Aug 21, 2005 | 02:43 PM
N20civicB18's Avatar
http://www.atpturbo.com/Mercha...e=SNS
http://www.hondata.com/tech3barmap.html
Old Aug 21, 2005 | 02:47 PM
Default Re: 3 bar map (N20civicB18)
ok, now can i hook the air line anywhere on the intake manifold
Old Aug 21, 2005 | 02:50 PM
ehh yeah pretty much, dont Tee it off of anything unless it is a big line IE. brake booster, if you do that Tee it before the check valve
Old Aug 21, 2005 | 03:03 PM
i have a piece that would remove old map sensor and hook airline to where it was but inside throttle body is a small hole, will this work or does it need the bigger hole
Topdawgg
Jun 25, 2007 10:02 AM
sleeprhatch
Sep 23, 2006 12:04 PM
SpoolnByYou
Dec 29, 2005 10:00 AM
integramic
Sep 7, 2004 01:44 PM
crx1856
Aug 31, 2003 01:58 AM
