***H22 TURBO***
***H22 TURBO***
I have an eg hatch, h22, and garrett t3/t4 turbo running bout 6psi, should I keep the 440cc injectors I bought or should I get bigger ones? Will it make a difference?
Car's not coming out of the garage till spring, so I got a little time to figure all this out. I think I need to get used to 6psi before I take it up any further. Thanks for the help guys
If you're planning on going higher than 6 psi, it might be a good time to get the bigger injectors, but it depends on how much power you're shooting for.
For what it's worth, I don't think I'd go above 6psi on an h22 unless it's built. If it's already built, ignore that last sentence
Re: ***H22 TURBO*** (Soon2havedelSlo)
I had 550 and was leaning out at 6-8psi on my H22. I stepped up to 880's. No probs now, cept for my blown cylinder 2
Re: (pheurton-skeurto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pheurton-skeurto »</TD></TR><TR><TD CLASS="quote">bullcrap...go for 9 or 10 lbs of boost. even if the h22 is stock. im running the dsm blue tops on my h22 at 10 lbs you should be fine with a good tune.</TD></TR></TABLE>
I kinda agree... im gona be running around 8-9 ... just get a good tune.. . its alllll about tunning! good luck
h22_crx
09-16-2005 05:00 AM
