bov not working
Old Aug 20, 2005 | 07:08 PM
boostin1cam's Avatar
Default bov not working
ok i put a blitz bov on my car and it wont work, don't know if we didn't hook up the right vacuum hose to the throttle body or what...the bov is off of an s14. and i have a d15b7 boosting only 5.5 psi. i don't know what's up. but if anybody could help me solve this thanks.
Old Aug 20, 2005 | 07:15 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: bov not working (93civcoupe)
do you know what boost levels the s4 was running? chances are it might have the stiff spring for use on applications over 18psi, in which case it would be too stiff to blow off on your car
Old Aug 20, 2005 | 07:19 PM
Default Re: bov not working (wantboost)
no i don't have ne idea what psi was being used..i bought it off of ebay, it's from Japan..it probably was higher psi than what i have. you think i would be able to find a spring not as stiff for my application somewhere...maybe on ebay?
Old Aug 20, 2005 | 07:20 PM
wantboost's Avatar
Who is Mr Robot?
you can call blitz. i think the standard spring is 20 bucks or so. just search around for blitz bov spring
Old Aug 20, 2005 | 07:31 PM
MooreBoost's Avatar
Also make sure you have it hooked up to a strong enough vac source off the manifold.
Alot of the nipples off the throttle body aren't strong enough to actuate a BOV.
a1320addict
Apr 29, 2005 06:01 PM
StolenTeg
Oct 24, 2004 06:24 PM
dunkd
Apr 25, 2004 02:35 PM
DeadLock23
Nov 13, 2003 08:39 PM
Liltrix
Nov 25, 2001 09:58 PM
