Flex downpipe?
Old Aug 24, 2005 | 04:29 PM
importnoodles's Avatar
Default Flex downpipe?
I'm just thinking of cheap alternatives. Would i be able to use flex pipe for a downpipe? As long as there is no exhaust leak anywhere BEFORE the flex pipe right? Also, would i be able to JB weld the DP to the exhaust flange?
Old Aug 24, 2005 | 04:37 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Flex downpipe? (importnoodles)
that probably won't work too well. you're gonna need a very long flex pipe to achieve that.
Old Aug 24, 2005 | 04:44 PM
beepy's Avatar
Default Re: Flex downpipe? (AzntaggeR)
Will flex pipe work for a downpipe? If you mean that universal stuff that you can pick up in the exhaust section of the auto parts store, then yes.
However, that stuff cannot make a bend tight enough for a downpipe, so you will still need mandrel bends. Also, it will not support any load, so you will need to support it at bother ends.
Can you use JB weld in the exhaust? No. You need to weld.
Old Aug 24, 2005 | 05:12 PM
Default Re: Flex downpipe? (beepy)
thanks
Old Aug 25, 2005 | 12:23 PM
Sketch_hs's Avatar
JB weld won't hold up to the heat. too bad.
that would be a cool product though.
2000 degree JB weld
opto_isolator
Jul 31, 2004 10:14 PM
MeanGreenEG9
Feb 25, 2003 01:38 PM
quikrpm'z
Nov 24, 2001 05:41 PM
B17aTrbo
Nov 16, 2001 08:53 PM
