BOOST on a GSR
Old Aug 20, 2005 | 03:59 AM
DutchEG6's Avatar
Default BOOST on a GSR
Here's my qeustion.
i'm busy with swapping a GSR engine into my eg6
in the future im going to boost
How much psi can i boost on stock head?
im planning to get a blockguard and some pistons and rods
because the gine is now out of the car so it's much easier to do it know.
so how much psi boost on a stock head?
Old Aug 20, 2005 | 04:47 AM
whoneedzvtec's Avatar
Default Re: BOOST on a GSR (DutchEG6)
well its not really about how much power ur head can hold, really its about how much ur bottom end can hold. u are gonna want to port ur head and possibly get a valve train so that it will flow better and u can rev it but its not the head u would be worryed about over exerting, unless ur trying to rev real high. anyways i hope i understood and answered ur question correctly and good luck with ur set-up.
Old Aug 20, 2005 | 05:10 AM
DutchEG6's Avatar
Default Re: BOOST on a GSR (dc2ls-t)
i now our button and isnt that strong..
that's why i gor low cr pistons, but the head with some good aftermarket springs and valves retainers is strong enough to boost like 15 psi to start?
or can i boost 15psi with stock head?
Old Aug 20, 2005 | 05:46 AM
turbochargeb18c's Avatar
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i now our button and isnt that strong..
or can i boost 15psi with stock head?</TD></TR></TABLE>
ive seen h-t member here boostin their stock gsr head and made pretty good hp....see,you got to understand that its your bottom end that is gonna be taken most of the abuse...not the head...if i were you,ill worry more bout my bottom end not holdin that 15psi than your head...and to answer your question,yes,you can boost 15 psi on a stock gsr head....well,hopefully this could help you out a little bit...good luck!!!
Old Aug 20, 2005 | 06:05 AM
DRIVENRacing's Avatar
ive seen over 20psi before and over 500whp on a stock gsr head
Old Aug 20, 2005 | 06:14 AM
DutchEG6's Avatar
thnx then i leave my head stock for the moment.
an go for some wiseco pistons and eagle rods
what cr should i take 9.9 or 9.1?
Old Aug 20, 2005 | 06:21 AM
BANNED
Default Re: (DutchEG6)
its all depend on what you want and your goals....if me, i would go stock compresson...now i got 9.7:1 ross pistons and its actually doing me good....so,its all up to you....
Old Aug 20, 2005 | 06:29 AM
DutchEG6's Avatar
Default Re: (turbochargeb18c)
if i go turbo i want to go defently 10+psi and more...
92db2gs-r
Apr 18, 2011 11:18 PM
Straight_jdm
Aug 14, 2007 10:03 AM
Mark
Sep 23, 2003 10:44 PM
tonesdef
Jun 11, 2003 05:47 PM
Markaccord95
Jan 28, 2002 10:43 AM
