Can I remove the wastegate??
Old Aug 20, 2005 | 09:03 AM
otto's Avatar
Default Can I remove the wastegate??
I broke a bolt on my manifold that connects the wg and now I need to drive the car without the wg to get it fixed. The question is will the car be ok to run without boost generated. I'm concerned about a/f ratio's and I do not have a gauge to tell me everything is ok. Thanks! HT
Old Aug 20, 2005 | 09:08 AM
N20civicB18's Avatar
Default Re: Can I remove the wastegate?? (otto)
Just get a bolt? Dont leave it open, if anything get a block off plate and bolt that down and dont even try to hit boost
Old Aug 20, 2005 | 09:09 AM
otto's Avatar
Default Re: Can I remove the wastegate?? (N20civicB18)
The bolt snaped off in the mani. I need to get it drilled out now.
Old Aug 20, 2005 | 01:34 PM
flip1199's Avatar
sure u can take it off and drive around. as long as u dont have a problem with burning hot exhuast gas filling up your engine bay
Old Aug 20, 2005 | 10:57 PM
TurboCoop's Avatar
Default Re: Can I remove the wastegate?? (flip1199)
A bolt rattled off of my WG and I drove home with it hanging on with one bolt, its just real loud and annoying. Just dont floor it and you'll be fine.
Old Aug 21, 2005 | 05:09 AM
Stewie's Avatar
Default Re: Can I remove the wastegate?? (TurboCoop)
take your hood off
Old Aug 21, 2005 | 06:20 AM
vtec.dc2's Avatar
i had this problem several times.. make sure to use grade 10 bolt and if that doesn't help, then its likely to break again because it must be hitting against something when engine moves.. as for driving, your car can overheat... a/f won't matter because you're not gonna be driving wot..
if you can't fix it yourself via screw extractor kit.. try securing with just one bolt.. then tie something to wastegate so if it comes loose it won't fall through.
Old Aug 21, 2005 | 06:44 AM
TurboCoop's Avatar
Default Re: Can I remove the wastegate?? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">make sure to use grade 10 bolt</TD></TR></TABLE>
I thought grade 8 was stronger than grade 10??? The pink ones are 8, thats what I always use.
Old Aug 21, 2005 | 06:49 AM
vtec.dc2's Avatar
no.. grade 10 are stronger than grade 8, grade 8 is what they sell in home depot/lowes
KKRIS
27
Feb 28, 2012 09:21 AM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
tdo
Oct 16, 2005 10:33 AM
-slow ej-
Mar 31, 2005 11:35 PM
hellas
Jan 21, 2003 12:33 PM
