GT3567R???
Old Aug 22, 2005 | 03:46 PM
99_GS-T's Avatar
Default GT35/T67 ballbearing turbocharger??? (GT3584R)
I have heard talk about a GT35R turbine side being matched to a T67 compressor wheel. Any vendors offering this combination? Just looking for a quick spooling street turbo with a little more airflow capacity then the GT35R.
None of the Garrett Vendors that I have talked to want to do it, but I am pretty sure it can be done fairly easily.
Old Aug 22, 2005 | 03:54 PM
ValleySyder's Avatar
Default Re: GT35/T67 ballbearing turbocharger??? (99_GS-T)
i would also like to know
Old Aug 22, 2005 | 04:05 PM
evilone's Avatar
Default Re: GT35/T67 ballbearing turbocharger??? (ValleySyder)
have you called Robert at forced performance??He might be able to help.
Old Aug 22, 2005 | 04:21 PM
99_GS-T's Avatar
Yeah, I've delt mostly with FP in the past. The FP3575 is not a GT35R based turbo, if that is what you are refering to. It is a T350/T67 though, and I've already got one of those.
Modified by 99_GS-T at 6:01 PM 8/22/2005
Old Aug 22, 2005 | 05:08 PM
Turbo-charged's Avatar
Default Re: (99_GS-T)
35R/67 lost a bunch of power last i talked to precision during testing over a standard 35R. not sure if any changes have been made yet?
Old Aug 22, 2005 | 06:27 PM
done's Avatar
Default Re: (Turbo-charged)
ITS can make you one..
I have a BB t350/t67 ... its a t4 though.
Old Aug 22, 2005 | 07:37 PM
TurboTegB18c's Avatar
Default Re: (Jordo@KAP)
Geoff at full race talked about something like this. Contact him. paul
Old Aug 22, 2005 | 08:14 PM
af-performance's Avatar
Banned
Default Re: (TurboTegB18c)
Hit up ken.
Phoenixturbo.com is his honda-tech name. I am sure he can help you with this turbocharger.
AF-P
Old Aug 22, 2005 | 11:17 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (af-performance)
Precision did make a few of these, but not many! You should try the GT37/67, it works pretty damn good for not being BB.
Old Aug 23, 2005 | 12:44 AM
J-Brooks's Avatar
Default Re: (Arturbo)
where can you find info on that turbo its not on their website
Old Aug 23, 2005 | 05:52 AM
99_GS-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Precision did make a few of these, but not many! You should try the GT37/67, it works pretty damn good for not being BB.</TD></TR></TABLE>
Originally, that is what I ordered from Forced Performance back in January. A T350/T67 in a T4 housing is what I got, for some reason. They tried to tell me the T350 is a cut down GT37...it may or may not be, but it certainly doesn't have the 66mm exducer of the GT37 that I wanted.
I was thinking GT35R turbine side just to help improve turbocharger service life. Part of the problem I have is the altitude I am at, 4200' in elevation. To make decent power means a high pressure ratio and very high shaft speeds. I figured the BB might help the turbo last longer. I would go straight GT35R, but when you calculate the corrected airflow, the GT35R is only capable of about 56 pounds/min of airflow at this altitude before it reaches choke flow. I don't think that will get me to my goal of 600 WHP (corrected). The T67 can produce about 68 pounds/min at this altitude, which will be much more likely to get me to my desired power levels.
Of course, the efficiency of the T67 at a 4:1 pressure ratio sucks, but I've got a pretty decent intercooler.
Natural Aspirations
Jun 4, 2014 05:41 AM
tasco
Sep 30, 2013 07:41 AM
jdm_vtec
Nov 17, 2006 03:37 PM
civic_hatchback
May 20, 2004 12:06 PM
Se-rv-Tak
Sep 24, 2003 02:54 AM
