Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (help with sizes)
Endyn Catch Can
Perrin Boost Solenoid
JG intake Manifold
Turbo
Tial 44mm Wastegate
Tial 50mm BOV
Each red number represents a port.
I need help finding the port sizes on.
Intake Manifold:
1. 1/8 NPT
2. 1/8 NPT
3. 3/8 NPT
4. 3/8 NPT
5. 1/8 NPT
Perrin Boost solenoid (same as apexi)
1. 1/8 NPT
2. 1/8 NPT
3. 1/8 NPT
And also Enydn Catch Can
1.
2.
3.
and back of motor where endyn catch can goes into..
1.
2.
Modified by Jordo@KAP at 5:04 PM 8/23/2005
Re: Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (Jordo@KAP)
intake manifold should either be the small 1/8 npt and i belive the larger on it 3/8npt
Updated
now i will get fittings and whatnot, and also post those, for everyone.
Jordo, you are one busy duck! Don't you ever stop doing something with your car already?
Re: Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (cinq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq »</TD></TR><TR><TD CLASS="quote">Jordo, you are one busy duck! Don't you ever stop doing something with your car already? </TD></TR></TABLE>
Its still not totally ready... But mostly, its truely my hobbie. I am doing all the work now, tuning and everything. Its much more fun this way.
Modified by Jordo@KAP at 7:52 PM 8/23/2005
Endyn (really Moroso) catch can has (two) 3/8" npt ports...don't know if you needed that info..but hey!
Re: Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">Endyn (really Moroso) catch can has (two) 3/8" npt ports...don't know if you needed that info..but hey! </TD></TR></TABLE>
Endyn has an extra 3/8" port welded on. Moroso cans (at least in that size), only come with one 3/8" port. They also sell them with -an fittings, but I forget the size.
Re: Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (USE2B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A »</TD></TR><TR><TD CLASS="quote">Endyn has an extra 3/8" port welded on. Moroso cans (at least in that size), only come with one 3/8" port. They also sell them with -an fittings, but I forget the size.</TD></TR></TABLE>
what about the fitting for the back of the motor??
z10 sells the fittings for the freeze plug...
next question.. if i have both tubes pluged into the drain plug, how would i tee the drain back into the motor?
Modified by Jordo@KAP at 9:59 PM 8/23/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP »</TD></TR><TR><TD CLASS="quote">
next question.. if i have both tubes pluged into the drain plug, how would i tee the drain back into the motor?</TD></TR></TABLE>
I don't understand what you mean that both tubes would be plugged into the drain plug.
Back of the block: M28 x 1.5
Endyn (Moroso) can: 3/8" on side/bottom
3/8" to -8AN works the best with the can
Jason
Jason
Re: Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (SFWD 1934)
i teed mine back into the passage side freeze plug whole like the endnye instructions say
Modified by Jordo@KAP at 9:59 PM 8/23/2005</TD></TR></TABLE>
its a oem part
its a oem part
Re: Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 »</TD></TR><TR><TD CLASS="quote">Back of the block: M28 x 1.5
3/8" to -8AN works the best with the can</TD></TR></TABLE>
I don't think there is an M28 x 1.5 to -an adapter. At least, I couldn't find one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">i teed mine back into the passage side freeze plug whole like the endnye instructions say</TD></TR></TABLE>
I did the same thing, but I didn't quite understand what he was asking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX »</TD></TR><TR><TD CLASS="quote">
its a oem part</TD></TR></TABLE>
He wants to use -an fittings, so that wouldn't work for him.
make one u wont see it so it wont have to look pretty take your freeze plug and bore a whole in it large enough to get rid of the hex then screw in a fitting im thinkin its gunna have to be atleast 1/2 but u might get a 3/8 to do the job. stuff a pipe-NA fitting in there and use a deep socket over the fitting to drive it in the whole. or if u bought the endyne kit bore thos out and use them??? some day im gunna re-do all my lines in NA short on money and time right now goodluck!!
GOIN V8 HUNTIN
12-12-2006 05:17 PM
boostcontroller
06-09-2003 08:01 AM
